29487 Discussions
sum intrinsic in constant expressions
tracyx
i want to define a parameter that is equal to the sum of a parameter array. in the code below covmatrix is a variance matrix, and i have 1's and 0's depending upon whether they are restricted or not. i want to define a parameter that tells me the number of unrestricted parameters:
[cpp]integer, parameter :: covmatrix(4,4) = reshape( &
& (/1, 0, 0, 0, &
& 1, 1, 0, 0, &
& 1, 1, 1, 0, &
& 1, 0, 1, 1/),(/4,4/))
integer, parameter :: numcov = sum(covmatrix)[/cpp]
however, this gives an error that "This intrinsic function is invalid in constant expressions". Is there an elegant way of calculating the number of ones in covmatrix? something like, integer, parameter :: numcov = covmatrix(1,1) + covmatrix(1,2) + ... works but it is tedious (especially if the dimension of covmatrix were to change). thanks
Les_Neilson
Valued Contributor II
Sorry. No
In the help, under "Initialization Expressions", SUM is shown as an example of an invalid initialization expression - though I can see how it could be useful.
Off the top of my head I can't think of an easy way to do it either.
Les
Jugoslav_Dujic
Quoting - Les Neilson
...me neither, other than the obvious workaround of not making it a parameter, and calculating the SUM (or COUNT) somewhere in the initialization stage.
ender01
Quoting - Jugoslav Dujic
Another idea is to use a wrapper. If you want to protect is as a parameter, have a wrapper calling function pass it with intent(in) and have your main consist of computing the sum and invoking the wrapper which effectively serves as your main.
Cheers,
Rich
jimdempseyatthecove
Quoting - tracyx
& (/1, 0, 0, 0, &
& 1, 1, 0, 0, &
& 1, 1, 1, 0, &
Tracy,
You might try using the Fortran Preprocessor
[cpp]#define parms
 1,0,0,0,
 1,1,0,0,
 1,1,1,0,
 1,0,1,1
#define parmsSum (a,b,c,d,e,f,g,h,i,j,k,l,m,n,o,p)
 a+b+c+d+e+f+g+h+i+j+k+l+m+n+o+p
integer, parameter :: covmatrix(4,4) = reshape( (/ parms /),(/4,4/))
integer, parameter :: numcov = parmsSum
Jim Dempsey
[/cpp]
JVanB
/stand:f03
tracyx
Quoting - Repeat Offender
/stand:f03
This doesn't work for me. I'm using 11.0.69.
To be clear: is the sum intrinsic in constant expressions part of F2003, but it just hasn't been implemented in Intel Fortran yet?
Thanks for all the suggestions, etc. I'm about to give up hope that this is easily doable in a parameter expression as some of the suggestions (e.g. wrapper function) do not work either.
ender01
Quoting - tracyx
Using the wrapper won't let you declare it as a parameter. However, if you pass the argument with the intent(in) attribute the compiler won't let you inadvertently change the value and you can use it in the scope of the called function as if it were a parameter (i.e., a named constant whose value cannot be changed). For instance:
[cpp]program main
   implicit none
   integer, dimension(4,4) :: covmatrix
   integer :: numcov
   covmatrix = reshape( (/1, 0, 0, 0, &
                      &   1, 1, 0, 0, &
                      &   1, 1, 1, 0, &
    call pseudo_main(numcov)
contains
    subroutine pseudo_main(constant)
        implicit none
        integer, intent(in) :: constant
        !  Put main here, use constant like a parameter (can't appear
! on LHS of an expression)
.... end subroutine pseudo_main end program main[/cpp]
The use of an intrinsic in an initialization expression is part of Fortran 2003 (subject to some limitations on the primaries of the expression (e.g., each primary is a constant or subobject of a constant)).
Cheers,
Rich
