sync image problem with Coarray Fortran
Zuodong_Y_
I learn from "Coarrays in the next Fortran Standard" by John Reid that following piece of code will make other images to wait for image 1
program main
	implicit none
	if(this_image()==1) then
		call sleep(1)
		sync images(*)
	else
		sync images(1)
	endif
	write(*,*)this_image()
	call sleep(10)
end program
I expect it take 11 seconds to finish. But it actually take 21s. The extra time is the time of second sleep(). It seems that image 1 is wait for image 2 to finish the whole code. If I remove the first sleep(), the time is 11 seconds as expected.
The program is compiled with ifort -coarray -coarray-num-images=2 using Intel(R) 64, Version 16.0.3.210 Build 20160415
Any idea?
Kevin_D_Intel
Development found the root cause. While your case did not exhibit the same behavior with 17.0, the possibility of the root cause still existed w/17.0; therefore, the fix will be applied to that release; likely the first update in the Q4 timeframe. The fix missed the upcoming final PSXE 2016 (16.0) update but will be applied to that branch in the event of a future unplanned update.
Kevin_D_Intel
I can reproduce the behavior you described with our current PSXE 2016 Update 3 (ifort 16.0.3.210) compiler but I cannot with our upcoming PSXE 2017 (ifort 17.0) compiler so it seems possible there is a defect with 16.0 responsible for the delay of image 1 when the sleep(1) is active.
I will make some inquiries with Development.
Zuodong_Y_
Thanks a lot for this information.
This problem slow my real program a lot. So if there is any progress, please let me know.
Thanks again.
Kevin_D_Intel
I reported the issue to Development for further investigation and to ensure we understand the underlying reason behind the change with 17.0. I will keep you updated about their findings.
(Internal tracking id: DPD200413377)
Kevin_D_Intel
