this is not a dec fortran module
rahzan
on a
use USER32, only:...
I am getting the compile error:
"this is not a dec fortran module"
on one of two installations of cvf6.6b. The other works ok.
The user32.mod seems to be in place (though no lib)
Does anyone have a clue on what might be wrong?
The compile is done via command line and environment variables are in place.
Tim
If you also have Intel Fortran installed, go to Tools..Options..Directories. For each of the categories, remove the Intel Fortran 7.1 folders from the list.
Steve
Jugoslav_Dujic
Valued Contributor II
Since he's compiling from command line, he'd better check INCLUDE environment variable first.
Oh, right. Installing Intel Fortran adds its folders to the INCLUDE, LIB and PATH environment variables. You'll want to remove those. I suggest not having the LIB and INCLUDE folders defined system-wide and starting the command prompt session using the appropriate shortcut in the CVF or Intel Fortran program group, which will define the right environment variables.
Steve
