traceback not working with openmpi
Craig_P_1
Hi, I'm compiling a code with the intel fortran compiler 11.1.046 and openmpi 1.3.3.  I'm trying to use the -traceback option to detect errors in my code, but it doesn't seem to be working when the code is compiled with mpi, only when a serial version of the code is compiled.  Is traceback supposed to work with an openmpi code?  Thanks!
The compiler options I'm using are:
-FR -assume byterecl -g -debug all -traceback -check all
and the link options are (not sure if I need these flags for linking, but I do it anyway):
The output I get with the serial version is:
forrtl: severe (408): fort: (7): Attempt to use pointer KINEDEN when it is not associated with a target
Image              PC                Routine            Line        Source
vasp5_debug        0000000000EF1C3D  Unknown               Unknown  Unknown
vasp5_debug        0000000000EF0745  Unknown               Unknown  Unknown
vasp5_debug        0000000000E9F249  Unknown               Unknown  Unknown
vasp5_debug        0000000000E4EF7D  Unknown               Unknown  Unknown
vasp5_debug        0000000000E4F382  Unknown               Unknown  Unknown
vasp5_debug        000000000044BDE8  MAIN__                   2593  main.F
vasp5_debug        0000000000404B8C  Unknown               Unknown  Unknown
libc.so.6          00000039C861D994  Unknown               Unknown  Unknown
vasp5_debug        0000000000404A99  Unknown               Unknown  Unknown
The output I get with the mpi version is:
vasp5_debug        00000000011FB9FD  Unknown               Unknown  Unknown
vasp5_debug        00000000011FA505  Unknown               Unknown  Unknown
vasp5_debug        00000000011B4419  Unknown               Unknown  Unknown
vasp5_debug        000000000116414D  Unknown               Unknown  Unknown
vasp5_debug        0000000001164552  Unknown               Unknown  Unknown
vasp5_debug        000000000048196D  Unknown               Unknown  Unknown
vasp5_debug        0000000000439F3C  Unknown               Unknown  Unknown
libc.so.6          00000031B441D994  Unknown               Unknown  Unknown
vasp5_debug        0000000000439E49  Unknown               Unknown  Unknown
mpiexec has exited due to process rank 5 with PID 5902 on
node compute-1-21.local exiting without calling "finalize". This may
have caused other processes in the application to be
terminated by signals sent by mpiexec (as reported here).
Craig_P_1
It also doesn't work with ifort 2013.0.079
It may be that OpenMPI is somehow preventing the traceback code from reading the executable. You're also using a very old compiler and it's possible that we made enhancements in the intervening years that resolved this. That it works in a serial program indicates that the traceback feature itself is functioning - I'm not sure what more we can do for you here.
Craig_P_1
Okay, thanks.  I'll see if I can try newer versions of ifort and openmpi
