29391 Discussions
truncation error in fortran compiler
仁义_许_
      program main
      integer , parameter :: QP = Selected_real_kind( 18 )
      real(kind=QP)::zb
      zb=-(4.76_QP-4.9_QP)*0.14_QP
      write(*,*)zb,0.14_QP*0.14_QP
      end
The result is
1.960000000000000000000000000000007E-0002
1.960000000000000000000000000000000E-0002
We should get the same results, but the reality is that the first one has a tail 7
I tried the code in
 Parallel Studio XE Cluster Edition for Windows* 2020
and oneAPI
Same results are obtained.
In iteration computation, this error is enlarged more and more.
Arjen_Markus
You make a very common mistake: the fact that 4.9 - 4.76 is 0.14 does not mean that in the binary system used by most computers, 4.9-4.76, even in in quadruple precision, is exactly 0.14. This only happens if the numbers happen to be exactly representable in that system. Compare it to 1/3 * 3 - if you represent the 1/3 as 0.33333...3, then the outcome of that calculation will not be exactly 1.0. Of course, rounding may lead to a 1.000....0 being printed, but that is a different matter.
I extended your program by calculating the difference between -(4.76_qp-4.9_qp) and 0.14_qp. Intel Fortran oneAPI gave me:
  4.814824860968089632639944856462318E-0034
and gfortran gave me:
   1.95999999999999999838E-0002   1.96000000000000000008E-0002
  -1.21972744404619248826E-0019
(the last number is this difference)
I do not know exactly how quadruple precision is implemented in these two compilers, but it is possible that one or both use a software library.
If your algorithm is indeed sensitive to this sort of round-off errors, then I suggest you use an arbitrary-precision library instead.
Arjen_Markus
