29279 Discussions
turn off warnings about array temporaries
vivekrao4
Compiling a code with IVF W_FC_C_9.1.037with the options
/Od /nologo /traceback /check:all /warn:all /warn:unused /gen-interfaces /warn:interfaces /debug:all
and running it I get many run-time messages such as
forrtl: warning (402): fort: (1): In call to I/O Write routine, an array temporary was created for argument #1
In general, I want to see warning messages, but how can I turn off the warnings about array temporaries?
Vivek Rao
Try adding /check:noarg_temp_created. Note that this is a run-time check and not a compile-time warning. I don't remember if you can selectively disable checks enabled with /check:all. You may have to replace that with a list of the /check options you want. Similarly, as you have /warn:all, explicitly enabling some specific warnings is redundant.
vivekrao4
Inserting /check:noarg_temp_created after /check:all removed the run-time warnings. Thanks.
Vivek Rao
