type (dialog) definition
Brooks_Van_Horn
I am in need of converting a HANDLE to a  type(dialog) variable and I cannot find the definition of type (dialog). I've searched IFLOGM.f90 for type dialog and found:
  type, public :: dialog
  sequence
  integer dlgid
  integer(HANDLE) hwnd  ! 0 if dialog is not displayed
  !private
  integer retval
  logical dirty  ! prevents unwanted callbacks when dlg values are changed
  logical mutexflush
  logical comboupdate
  integer(UINT_PTR) dlginitcallback
  integer NumControls
  type (ControlType), pointer, dimension(:) :: list
  end type
If I have a hDlg passed to a routine, how do I associate the same dialog with the type (dialog) dlg variable by setting  the dlgid variable and the hwnd variable too?
Brooks V
andrew_4619
I don't really understand the question, I think you need to clarify a little.
When you call DLGINIT ( result = DLGINIT (id,dlg)) dlg is a variable of type dialog that becomes associated with the dialog resource identifier ID.
Later when you call DLGMODAL (or DLGMODELESS) with that dlg variable it will become associated with a Windows handle to the dialog. This will be stored in dlg%hwnd if you need access to it.
TYPE(DIALOG) belongs to the IFLOGM module and is meaningful only to the routines there. It isn't something you can create from a handle.
Like Andrew, I'd like to see more of what you're trying to do.
