unformatted write of allocatable data structure
Guthrie_M_
This is confusing, because it seems to work with the Intel compiler (2015) when the write is done in the same program before the read.
The compile fails with G95 giving the error message
         write(1)TestData
                 1
Error: Data transfer element at (1) cannot have ALLOCATABLE components
Here is the example code. Invoke with "test" to write first and "test 1" to attempt to read the old file, which fails. Why?
      implicit none
      integer::i
      character(len=1)::buf
      logical::WriteFileFirst=.false.
      type TestType
         real*8,dimension(:),allocatable::a
      end type TestType
      type(TestType),dimension(:),allocatable::TestData
      call getarg(1,buf)
      if(buf.ne."")then
         write(*,*)'using old file'
      else
         WriteFileFirst=.true.
         write(*,*)'Writing file first'
      endif
      allocate(TestData(3))
      do i=1,3
         allocate(TestData(i)%a(2))
      enddo
      if(WriteFileFirst)then
         do i=1,3
            TestData(i)%a(1)=3
            TestData(i)%a(2)=4
         enddo
         open(1,file='TestData',form='unformatted')
         write(1)TestData
         close(1)
      endif
      read(1)TestData
      close(1)
      write(*,*)'TestData(1)=',TestData(1)
      end
IanH
Objects of a type that has pointer or allocatable components have to be handled by a defined input/output procedure for the type (that's the culmination of a series of rules in F2008 9.6.3p7 around how items in an input/output list are expanded).  There is no such procedure in your code.
I'd expect a diagnostic from the compiler for this code, though the standard doesn't formally require such a diagnostic.
Steven_L_Intel1
Indeed, Intel Fortran ought to give an error for this program. I will let the developers know.
Guthrie_M_
Thanks for the quick replies. And, how could I fix this example code so it would work?
IanH
You could provide defined input/output procedures for your type with allocatable components.
An example attached, with the unformatted and formatted representations chosen arbitrarily.
(While writing this I see that the compiler should also be complaining about the formatted output of the object as well as the unformatted input/output operations.)
module TestTypes
  implicit none
  private
  integer, parameter :: rk = KIND(1.0D0)
  type, public :: TestType
     real(rk),dimension(:),allocatable::a
  end type TestType
  public :: write(formatted)
  public :: read(unformatted)
  public :: write(unformatted)
  interface write(formatted)
    procedure write_formatted
  end interface write(formatted)
  interface read(unformatted)
    procedure read_unformatted
  end interface read(unformatted)
  interface write(unformatted)
    procedure write_unformatted
  end interface write(unformatted)
contains
  subroutine write_formatted(dtv, unit, iotype, v_list, iostat, iomsg)
    class(TestType), intent(in) :: dtv
    integer, intent(in) :: unit
    character(*), intent(in) :: iotype
    integer, intent(in) :: v_list(:)
    integer, intent(out) :: iostat
    character(*), intent(inout) :: iomsg
    write (unit, "(L1,1X)", IOSTAT=iostat, IOMSG=iomsg) allocated(dtv%a)
    if (iostat /= 0) return
    if (allocated(dtv%a)) then
      write (unit, *, IOSTAT=iostat, IOMSG=iomsg)  &
          lbound(dtv%a), ubound(dtv%a), dtv%a
    end if
  end subroutine write_formatted
  subroutine write_unformatted(dtv, unit, iostat, iomsg)
    write (unit, IOSTAT=iostat, IOMSG=iomsg) allocated(dtv%a)
      write (unit, IOSTAT=iostat, IOMSG=iomsg)  &
    end if
  end subroutine write_unformatted
  subroutine read_unformatted(dtv, unit, iostat, iomsg)
    class(TestType), intent(inout) :: dtv
    logical :: alloc
    integer :: lower
    integer :: upper
    if (allocated(dtv%a)) deallocate(dtv%a)
    read (unit, IOSTAT=iostat, IOMSG=iomsg) alloc
    if (alloc) then
      read (unit, IOSTAT=iostat, IOMSG=iomsg) lower, upper
      allocate(dtv%a(lower:upper))
      read (unit, IOSTAT=iostat, IOMSG=iomsg) dtv%a
    end if
  end subroutine read_unformatted
end module TestTypes
  use TestTypes
  implicit none
  integer::i
  call getarg(1,buf)
  if(buf.ne."")then
  else
  endif
  do i=1,3
  enddo
     do i=1,3
        TestData(i)%a(1)=3
        TestData(i)%a(2)=4
     enddo
     write(1)TestData
     close(1)
  endif
  read(1)TestData
  close(1)
end
Guthrie_M_
Wow! Many cool things. Thanks for all that. Your code didn't compile with Intel or G95 right off, but I'm working on it.
In my experimenting I discovered that while write(1)TestData does not produce a file that is readable outside the program itself (by read(1)TestData), the following does work
         write(1)(TestData(i)%a,i=1,3)
         close(1)
which can be read using
      read(1)(TestData(i)%a,i=1,3)
      close(1)
So it looks like a quick and dirty work around for read/wirte involving data structures is to explicitly refer to the elements of the structure.
Steven_L_Intel1
G95 won't support user-defined derived type I/O. I don't think gfortran has that yet either.
Steven_L_Intel1
Missing errors escalated as issue DPD200408497.
JohnNichols
Valued Contributor III
Thanks - I will use this if that is ok.
Which is better rk = KIND(1.0D0) or the kind(15,307)?
John
module TestTypes
  implicit none
  private
  end type TestType
contains
    end if
    end if
    logical :: alloc
    integer :: lower
    integer :: upper
    if (alloc) then
    end if
  use TestTypes
  implicit none
  integer::i
  call getarg(1,buf)
  if(buf.ne."")then
  else
  endif
  do i=1,3
  enddo
     do i=1,3
        TestData(i)%a(1)=3
        TestData(i)%a(2)=4
     enddo
     write(1)TestData
     close(1)
  endif
  read(1)TestData
  close(1)
end
Steven_L_Intel1
The missing errors will be fixed in a future major release of the compiler (not the one this year.)
