unlimited polymorphic parameter and transfer intrinsic
Franck_R_
Trying to use polymorphism with the transfer intrinsic, I ran into a behaviour that I don't understand.
With the following test program, i get the following output :
storage req. size =           16
text = h!O�p!O��
If I replace "class default" with "class is (str)", I get the expected :
text = hello !
Am I doing something wrong ?
Thanks !
Franck
module polymorphic
   character(len=1), private, dimension(:), allocatable :: storage
   type  str
       character(len=16) :: text
   end type str
contains
   subroutine store(arg)
      implicit none
      class(*), intent(in)      :: arg
      integer   :: i_size
      type(str) :: probe
      select type (arg)
!         class is (str)
         class default
            i_size = size(transfer(arg,storage))
            write (*,*) ' storage req. size = ',i_size
            allocate(storage(i_size))
            storage = transfer(arg,storage)
            probe = transfer(storage, probe)
            write (*,*) 'text = ', probe%text
     end select
   end subroutine store
end module polymorphic
program test_polymorphic
  use polymorphic
  type(str) :: input
  input%text = 'hello !'
  call store(input)
end program test_polymorphic
Steven_L_Intel1
With "class default" and a class(*) selector, arg is polymorphic and has no declared type. I'm unsure if it's really legal to reference arg in that context. The definition of TRANSFER says that the source can be "any type" but it in fact has NO type. The compiler really ought to give you an error here, but I want to research this some more before I file a bug report.
Nevertheless, I don't think you can get away with what you're doing here.
Steven_L_Intel1
Ok, did some more research and I concluded that this ought to work. It seems we're not handling polymorphic arguments to TRANSFER correctly. (Interpretation F03/0047 confirmed that either SOURCE or MOLD may be polymorphic.)  I filed issue DPD200408903 about this and will let you know of any progress.
jimdempseyatthecove
Steve,
What happens with transfer in the above when inside type str, text is declared as allocatable?
Wouldn't then the (image of the) array descriptor be treated as the character(1) array?
Jim Dempsey
Steven_L_Intel1
Yes, I think that's what would happen.
Franck_R_
Thanks a lot Steve. Quick and accurate answer.
Do you ever stop monitoring the forum ? (first part of your answer was on Sunday night, right ?)
Franck
Steven_L_Intel1
Yes, that was Sunday night. Bugs never sleep.
Steven_L_Intel1
I expect this bug to be fixed in Update 2 to Parallel Studio XE 2017.
