29245 Discussions
unlimited polymorphic variables and multi-threading results in crash
Tobias_Loew
the following code has a (very trivial) implementation of an auto-growing array (called "list"), where each instance of it can hold a different type. It works well, as long you don't use it multi-threaded:
If you compile the code with /Qopenmp it will simply crash!
The reason is (and I couldn't believe when I saw it in the assembler code) that inside of the append-subroutine at run-time the currently used type is switched and written to GLOBAL STATIC memory. This is simply insane, and I cannot find any reason, why this information is not written onto the stack or at least in thread-local storage when /threads is specified.
Tobias
    module test_mod
    implicit none
    type list
        class(*), allocatable :: c(:)
        integer :: num_nodes
    contains
    procedure :: append
    end type
    contains
    subroutine append(this,element)
    class(list) :: this
    class(*), intent(in) :: element
    class(*), allocatable :: tmp(:)
    integer :: l
    if (.not.allocated(this%c)) then
        allocate(this%c(1),source=element)
        this%c(1) = element
        this%num_nodes = 1
        return
    else
        l = size(this%c,1)
        allocate(tmp(l+1),source=element)
        tmp(1:l) = this%c(1:l)
        tmp(l+1) = element
        deallocate(this%c)
        call move_alloc(tmp,this%c)
        this%num_nodes = this%num_nodes + 1
    endif
    end subroutine
    subroutine test()
    type(list) :: lines
    type(list) :: ilines
    character(256):: line
    integer:: err,cnt,i,file_unit
    !Init:
    cnt = 1
    DO i=1,100
        line = 'hello'
            call append(lines,line)
            call append(ilines,i)
    end do
    end subroutine
    end module
    program Console1
    use test_mod
    implicit none
    integer loop_t, nr_temps
    nr_temps = 20000
    !$omp parallel do
    do loop_t = 1,nr_temps
        call test()
    end do
    !$omp end parallel do
    end program Console1
Steve_Lionel
From the OpenMP spec:
This OpenMP API specification refers to ISO/IEC 1539-1:2010 as Fortran 2008. While future versions of the OpenMP specification are expected to address the following features, currently their use may result in unspecified behavior.
Submodules
Coarrays
DO CONCURRENT
Allocatable components of recursive type
Pointer initialization
Value attribute is permitted for any nonallocatable nonpointer nonarray
Simply contiguous arrays rank remapping to rank>1 target
Polymorphic assignment
Accessing real and imaginary parts
Pointer function reference is a variable
Recursive I/O
The BLOCK construct
EXIT statement (to terminate a non-DO construct)
ERROR STOP
Internal procedure as an actual argument
Generic resolution by procedureness
Generic resolution by pointer vs. allocatable
Impure elemental procedures
Steve_Lionel
That said, I think what you have found would likely be considered a bug and I recommend that you report this to Intel using the Online Service Center.
Tobias_Loew
Hello Steve,
thanks for your reply, but this is not an OpenMP problem, I just used OpenMP to show the problem.
The problem is that the subroutine "append" is not thread-safe, even though /threads is specified. So, this code is invalid in any multi-threaded context (e.g. when it is inside a dll that is used from some multi-threaded C++ code). Further, I couldn't find any comment in the intel-fortran-docs about unlimited polymorphic variables may resulting in non thread-safe code.
Steve_Lionel
Can you highlight for me the assembly that you think is at issue? I'm having difficulty identifying it.
In the absence of /Qopenmp, the routines are not RECURSIVE and therefore not thread-safe. (That will change with Fortran 2018, which makes routines recursive by default.)  /threads is an obsolete option that selects between thread-safe and non-thread-safe run-time libraries; the latter no longer exists so /threads is a no-op. You probably want /recursive.
Tobias_Loew
This is from the assembler x64/Release. The problematic lines are all the
mov qword ptr [__scrt_ucrt_dll_is_in_use+228h (07FF7583F9768h)]...
which write to the global rw-memory of the process, as you can see from address of the exe's image:
Console1.exe    Console1.exe    C:\Users\k8705963\source\repos\Console1\x64\Release\Console1.exe    N/A    N/A    Symbols loaded.    C:\Users\k8705963\source\repos\Console1\x64\Release\Console1.pdb    1        2/9/2020 6:07 PM    00007FF7583F0000-00007FF7583FF000    [49976] Console1.exe
the code results from line 28 in Console1.f90
tmp(l+1) = element
(I've attached the project). (In x86 builds the problem also exists, but assembler doesn't show it so nice.)
Further down in the assembly, there are again writes to global memory.
Tobias
00007FF7583F16FA  mov         qword ptr [r10+20h],0
00007FF7583F1702  call        for_alloc_assign_v2 (07FF7583F45A4h)
        tmp(l+1) = element
00007FF7583F1707  mov         rbx,qword ptr [rsp+168h]
00007FF7583F170F  lea         rcx,[__scrt_ucrt_dll_is_in_use+220h (07FF7583F9760h)]
00007FF7583F1716  imul        r12,rbx
00007FF7583F171A  mov         qword ptr [r13+18h],rsi
00007FF7583F171E  mov         rsi,qword ptr [rsp+1A0h]
00007FF7583F1726  imul        rsi,rbx
00007FF7583F172A  mov         rdx,qword ptr [rsp+160h]
00007FF7583F1732  add         rdx,r12
00007FF7583F1735  add         rdx,rbx
00007FF7583F1738  mov         rax,qword ptr [rsp+1A8h]
00007FF7583F1740  sub         rdx,rsi
00007FF7583F1743  mov         rbp,qword ptr [rsp+1B0h]
00007FF7583F174B  mov         qword ptr [__scrt_ucrt_dll_is_in_use+228h (07FF7583F9768h)],rbx
00007FF7583F1752  mov         qword ptr [__scrt_ucrt_dll_is_in_use+220h (07FF7583F9760h)],r14
00007FF7583F1759  mov         qword ptr [__scrt_ucrt_dll_is_in_use+250h (07FF7583F9790h)],rax
00007FF7583F1760  mov         qword ptr [__scrt_ucrt_dll_is_in_use+258h (07FF7583F9798h)],rbp
00007FF7583F1767  mov         qword ptr [__scrt_ucrt_dll_is_in_use+270h (07FF7583F97B0h)],r14
00007FF7583F176E  mov         qword ptr [__scrt_ucrt_dll_is_in_use+280h (07FF7583F97C0h)],r14
00007FF7583F1775  mov         qword ptr [__scrt_ucrt_dll_is_in_use+278h (07FF7583F97B8h)],r14
00007FF7583F177C  mov         qword ptr [__scrt_ucrt_dll_is_in_use+268h (07FF7583F97A8h)],r14
00007FF7583F1783  mov         qword ptr [__scrt_ucrt_dll_is_in_use+288h (07FF7583F97C8h)],r14
00007FF7583F178A  mov         qword ptr [__scrt_ucrt_dll_is_in_use+290h (07FF7583F97D0h)],r14
00007FF7583F1791  mov         qword ptr [__scrt_ucrt_dll_is_in_use+238h (07FF7583F9778h)],443h
00007FF7583F179C  mov         qword ptr [__scrt_ucrt_dll_is_in_use+240h (07FF7583F9780h)],r14
00007FF7583F17A3  mov         qword ptr [__scrt_ucrt_dll_is_in_use+230h (07FF7583F9770h)],r14
00007FF7583F17AA  call        for_finalize (07FF7583F459Eh)
00007FF7583F17AF  mov         r9,qword ptr [rsp+160h]
00007FF7583F17B7  mov         rax,rsp
00007FF7583F17BA  add         r9,r12
00007FF7583F17BD  mov         rcx,r13
00007FF7583F17C0  mov         r12,qword ptr [rsp+1A0h]
00007FF7583F17C8  add         r9,rbx
00007FF7583F17CB  imul        r12,rbx
00007FF7583F17CF  sub         r9,r12
00007FF7583F17D2  mov         rdx,rdi
00007FF7583F17D5  lea         r8,[__scrt_ucrt_dll_is_in_use+220h (07FF7583F9760h)]
00007FF7583F17DC  mov         qword ptr [rax+20h],0
00007FF7583F17E4  call        for_alloc_assign_v2 (07FF7583F45A4h)
        deallocate(this%c)
00007FF7583F17E9  mov         rcx,qword ptr [r15]
00007FF7583F17EC  mov         rdx,qword ptr [rcx]
00007FF7583F17EF  or          qword ptr [rcx+18h],400h
Tobias_Loew
I forgot to mention, the version I'm using is
Intel® Parallel Studio XE 2019 Update 5 Composer Edition for Fortran Windows* Integration for Microsoft Visual Studio* 2019, Version 19.0.0052.16
Steve_Lionel
Ok, I see it now. I am not sure what that code is doing - looks to be setting up some sort of data structure, perhaps for later use by a call to for_finalize, but I am not sure. Regardless, I agree it should not be using static storage for that. Please submit a report through the OSC.
jimdempseyatthecove
Hmm, quite interesting bug.
The call to for_finalize is shown to be using static storage for context information, yet during testing at Intel (IMHO) this bug did not exhibit an issue due to the fact (presumption on my part) that the test procedures were more (or less) well constructed parallel programming examples. By this, I mean that your allocate subroutine itself is not thread-safe from the source code perspective... however, in your test program usage, the specific list objects are not used by multiple threads (created, used, and destroyed within each thread context). In testing at Intel, it was likely that similar typed objects which call for_finalize were located in the master thread context.
Good catch on presenting a simple test program that illustrates the bug. You will need to combine your report in #6 with #1. Otherwise the software support person may assume the issue is related to append not being coded in a thread-safe manner. Then you will have to explain that each instance of object list is used thread-independently.
Jim Dempsey
jimdempseyatthecove
Tobias,
Out of curiosity, and perhaps as an acceptable work-around for others, what happens if you add to your list type a FINAL subroutine? It doesn't have to do much, in this case to delete C when C is allocated. IIF this omits the CALL to for_finalize, then the problem can be avoided with minimal code changes.
Jim Dempsey
Tobias_Loew
Jim,
thanks for your comments. I've tried your suggestion with the FINAL subroutine, but the program still crashes when run multi-threaded.
Tobias
jimdempseyatthecove
FWIW, this would be the fix:
subroutine append_single(this,element)
  class(list) :: this
  integer :: l
    this%c(1) = element
    this%num_nodes = 1
    return
  else
    l = size(this%c,1)
    tmp(l+1) = element
    deallocate(this%c)
  endif
end subroutine append_single
  class(list) :: this
  !$omp critical(for_finalize_critical) ! same name to be used on all procedures with finalize
  call append_single(this,element)
  !$omp end critical(for_finalize_critical)
Jim Dempsey
Tobias_Loew
Jim,
thanks for the code. This will fix the problem for OpenMP-multithreading, but unfortunately not for general multi-threading. The library, where this error occurs, is used from all kind of top-level languages, e.g. C, C++, Python or Excel-VBA, but AFAIK Fortran doesn't have any general (not OpenMP) multi-threading primitives.
For now, that code will be replaced by a specific list-implementation for each type, which won't need a critical-section, as this would be a huge performance-bottleneck. As a side-effect, that is also type-safer, since you cannot call the append of an integer-list implementation with a character(256). (In the "unlimited polymorphic" above code that would compile without error but result in a run-time crash.)
jimdempseyatthecove
Out of curiosity, in looking at your sample code, and ignore the fact that the following might not be how you intend to use the code, consider:
        call append(lines,i)     ! same list object, different type
What do you expect append to do???
Jim Dempsey
FortranFan
Readers will find it useful if OP can illustrate the steps taken and make an attempt to show what is meant by a crash - is it some exception from the run-time library such as "forrtl: severe (189): LHS and RHS of an assignment statement have incompatible types".
If it's the severe exception 189, it points either to faulty code or as indicated in Quote #2 some "unspecified behavior" that is forewarned in OpenMP documentation.
Any discussion appears meaningless until OP can show the details.
C:\Temp>type test_mod.f90
module test_mod
   implicit none
   type list
   contains
      procedure :: append
   end type
contains
      class(list) :: this
      integer :: l
         this%c(1) = element
         this%num_nodes = 1
         return
      else
         l = size(this%c,1)
         tmp(l+1) = element
         deallocate(this%c)
      endif
   end subroutine
   subroutine test()
   !DIR$ ATTRIBUTES DLLEXPORT :: test
      type(list) :: lines
      !Init:
      cnt = 1
      DO i=1,100
         line = 'hello'
      end do
   end subroutine
end module
C:\Temp>ifort /dll /standard-semantics /warn:all /stand:f18 /recursive /reentrancy:threaded /libs:static /threads test_mod.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.1.0.166 Build 20191121
Copyright (C) 1985-2019 Intel Corporation.  All rights reserved.
test_mod.f90(37): warning #7025: This directive is not standard F2018.
test_mod.f90(42): remark #7712: This variable has not been used.   [ERR]
test_mod.f90(42): remark #7712: This variable has not been used.   [FILE_UNIT]
Microsoft (R) Incremental Linker Version 14.24.28316.0
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:test_mod.dll
-dll
-implib:test_mod.lib
test_mod.obj
   Creating library test_mod.lib and object test_mod.exp
C:\Temp>type Console1.f90
program Console1
   use test_mod
   implicit none
   nr_temps = 20000
   !$omp parallel do
      call test()
   end do
C:\Temp>ifort /c /Qopenmp /standard-semantics Console1.f90
C:\Temp>link Console1.obj test_mod.lib /subsystem:console /out:Console1.exe
C:\Temp>Console1.exe
C:\Temp>
jimdempseyatthecove
FF,
Do you think the error message is due to deallocate(this%c), and thus making the class(*) C(:) undefined. IOW when used as rhs it now has no class type, and thus differs from lhs.
In your test setup, what happens when you comment out the deallocate(this%c)? IOW letting move_alloc perform the deallocation (possibly after the compiler type checking code completes).
Jim Dempsey
Tobias_Loew
Please let me make this clear:
The original code runs absolutely fine and is bug-free as long as it runs single-threaded.
As pointed out in #6, the problem is that prior to the call of for_finalize the global (!) state of the module is changed, which yields code that is inherently not thread-safe.
This is unexpected, since the /threads (multithreaded-runtime) and /Qauto (implicitly by /Qopenmp) are specified, and none of the used language features in the append-subroutine is documented to be not thread-save. (All variables are visible to just one thread.)
IMHO the compiler produces invalid code, otherwise the option /threads would be meaningless (at least when unlimited polymorphism is used).
Tobias
FortranFan
The original code runs absolutely fine and is bug-free as long as it runs single-threaded. ..
Can you not follow the go-by in Quote #15 to better illustrate the problem so other readers who may be similarly affected can consider the workarounds/fixes suggested by Black Belts such as Jim?
Aspects such as "the compiler produces invalid code" can help Intel Fortran team with whenever they implement a resolution but they hardly suggest to other readers what to do if they face issues with polymorphic objects and their assignments etc. in an OpenMP context.
FortranFan
jimdempseyatthecove (Blackbelt) wrote:
FF,
Do you think the error message is due to deallocate(this%c), and thus making the class(*) C(:) undefined. IOW when used as rhs it now has no class type, and thus differs from lhs. ..
Possibly.  To me, the code in subprogram 'append' makes little sense given the use of unlimited polymorphic objects.  So I'm not going to look too much further.  It'll be useful if OP can follow up better.
Tobias_Loew
Hello FortranFan,
I've uploaded the project in #6, so anyone interested can download, compile and run it. Furthermore, you have shown the errors in #15. The code is also not faulty: if you run it single-threaded it works, also if you comment out line 49 or line 50 from the code in #1 it also works multi-threaded (OpenMP or not doesn't matter).
I've analyzed the assembly code and convinced Steve Lionel (a black-belt, in case that matters) that this is definitely not an OpenMP related problem but a problem in the compiler: dynamically switching the information of the runtime-type at fixed addresses in static global memory is simply a bad decision.
Tobias
jimdempseyatthecove
Once you showed the disassembly code in #6 it was clear that this was a compiler error. Everything since then by other posters were constructive posts as to how to work around the problem. These instructive postings were not only directed to you, but to any of the other readers of this forum that may have come across this issue. Waiting on software support to fix the problem in the compiler is not a choice that many can afford to take.
Also, neither /auto nor /Qopenmp makes your code definitively thread-safe. Your append code, as an example, even with a compiler fix to not use static storage as the bug does now, would not be thread-safe with concurrent calls on the same list object. Nearly all of the execution statements would require being in a critical section.
Jim Dempsey
