I have tried and failed to use SHBrowseForFolder. I can't find a module with the BROWSEINFO structure defined, so I have defined my own. So then I find that SHBrowseForFolder is not defined anywhere either. I have to admit that I am floundering here and have no idea what to do. Please can someone explain how to use this function, including how to declare all the bits I need.
With many thanks in advance,
Mike
If you type 'shbrowseforfolder' in the search box below, you will find some useful info from these boards....
For a start, try this link http://softwareforums.intel.com/ids/board/message?board.id=5&message.id=10508&highlight=shbrowseforfolder#M10508
Message Edited by anthonyrichards on 01-24-2005 12:44 AM
See the attached sample code.
