29383 Discussions
use of cdfnorminv function: how to make use of this function in a fortran code, provide working ex
ll1240
! file: mkl_norminv_vml.f90
! ifx mkl_norminv_vml.f90 -qmkl
program test_mkl_cdfnorminv
use, intrinsic :: iso_c_binding
implicit none
interface
subroutine vdCdfNormInv(n, a, y) bind(C, name="cdfnorminv")
!import :: c_int, c_double
integer :: n
real(8) :: a(1)
real(8) :: y(1)
end subroutine vdCdfNormInv
end interface
real(8) :: p(1), x(1)
p(1) = 0.90d0
call vdCdfNormInv(1, p, x) ! x = Φ^{-1}(p)
WRITE(*,'((a10),f18.8)') "out vdCdF", x(1)
!print '(a,f8.4)', '90th percentile of N(0,1): ', x(1)
end program test_mkl_cdfnorminv
***  and provide all the instruction to compile , link and run, please.
i've tried implementing the Acklam algo, feeded with rand() , it provides numerical results but not gaussian distributed.
      FUNCTION inv_normal_ack(p, mu, sigma) result(x)
            ! use of the instruction result
        IMPLICIT NONE
        REAL(8), INTENT(in) :: p, mu, sigma
        REAL(8) :: x, z
        REAL(8) :: q, r
        ! Coefficients for Acklam approximation
        REAL(8), PARAMETER :: a1 = -3.969683028665376d0
        REAL(8), PARAMETER :: a2 =  2.209460984245205d0
        REAL(8), PARAMETER :: a3 = -2.759285104469687d0
        REAL(8), PARAMETER :: a4 =  1.383577518672690d0
        REAL(8), PARAMETER :: a5 = -3.066479806614716d-1
        REAL(8), PARAMETER :: a6 =  2.506628277459239d-2
        REAL(8), PARAMETER :: b1 = -5.447609879822406d0
        REAL(8), PARAMETER :: b2 =  1.615858368580409d0
        REAL(8), PARAMETER :: b3 = -1.556989798598866d-1
        REAL(8), PARAMETER :: b4 =  6.680131188771972d-3
        REAL(8), PARAMETER :: c1 = -7.784894002430293d-3
        REAL(8), PARAMETER :: c2 = -3.223964580411365d-1
        REAL(8), PARAMETER :: c3 = -2.400758277161838d0
        REAL(8), PARAMETER :: c4 = -2.549732539343734d0
        REAL(8), PARAMETER :: c5 =  4.374664141464968d0
        REAL(8), PARAMETER :: c6 =  2.938163982698783d0
        REAL(8), PARAMETER :: d1 =  7.784695709041462d-3
        REAL(8), PARAMETER :: d2 =  3.224671290700398d-1
        REAL(8), PARAMETER :: d3 =  2.445134137142996d0
        REAL(8), PARAMETER :: d4 =  3.754408661907416d0
        ! Define breakpoints
        REAL(8), PARAMETER :: plow = 0.02425d0
        REAL(8), PARAMETER :: phigh = 1.0d0 - plow
        IF (p <= 0.0d0 .or. p >= 1.0d0) THEN
            WRITE(*,'(a)') "Error: p must be in [0 1]"
            stop
        END IF
        ! Compute z for standard normal
        IF (p < plow) THEN
            q = sqrt(-2.0d0 * log(p))
            z = (((((c1*q+c2)*q+c3)*q+c4)*q+c5)*q+c6) / &
                ((((d1*q+d2)*q+d3)*q+d4)*q+1.0d0)
        ELSE IF (p > phigh) THEN
            q = sqrt(-2.0d0 * log(1.0d0 - p))
            z = -(((((c1*q+c2)*q+c3)*q+c4)*q+c5)*q+c6) / &
        ELSE
            q = p - 0.5d0
            r = q*q
            z = (((((a1*r+a2)*r+a3)*r+a4)*r+a5)*r+a6)*q / &
                (((((b1*r+b2)*r+b3)*r+b4)*r+1.0d0))
        END IF
        ! Scale to given mean and std dev
        x = mu + sigma * z
      RETURN
      END FUNCTION inv_normal_ack
JohnNichols
Valued Contributor III
implicit none
interface
integer :: n
real(8) :: a(1)
real(8) :: y(1)
end interface
p(1) = 0.90d0
        IMPLICIT NONE
        REAL(8) :: x, z
        REAL(8) :: q, r
            stop
        END IF
        IF (p < plow) THEN
        ELSE
            q = p - 0.5d0
            r = q*q
        END IF
        x = mu + sigma * z
      RETURN
Question 1: Please explain why I should have to show you how to compile a Fortran program, the usual method is to read the manual.
Question 2: Why do you assume that RAND gives you Random numbers that are Gaussian, we know it is a lousy RND, has been since it was developed for Microsoft Fortran
Question 3: Is this a school assignment, a PhD thesis stuff or work related?  All of those mean you should do it on your own to learn?
Also read the manual on posting properly.    and ***  and provide all the instruction to compile , link and run, please. == why should volunteers who spent years programming and learning do this for you?
These people help, but you have to make the first effort at getting it working.
mecej4O
You have already got the pieces that you need. Put the following lines into a Fortran source file, say, "tstcdf.f90":
implicit none
integer :: n
p(1) = 0.90d0
call vdCdfNormInv(1, p, x) ! x = F^{-1}(p)
Compile and link using the command
ifx -qmkl tstcdf.f90
and run using the command
./a.out
and you should see the output
out vdCdF 1.28155157
You do not need Acklam's code -- it does the same thing that the MKL routine vdCdfNormInv does.
