! file: mkl_norminv_vml.f90
! ifx mkl_norminv_vml.f90 -qmkl
program test_mkl_cdfnorminv
use, intrinsic :: iso_c_binding
implicit none
interface
subroutine vdCdfNormInv(n, a, y) bind(C, name="cdfnorminv")
!import :: c_int, c_double
integer :: n
real(8) :: a(1)
real(8) :: y(1)
end subroutine vdCdfNormInv
end interface
real(8) :: p(1), x(1)
p(1) = 0.90d0
call vdCdfNormInv(1, p, x) ! x = Φ^{-1}(p)
WRITE(*,'((a10),f18.8)') "out vdCdF", x(1)
!print '(a,f8.4)', '90th percentile of N(0,1): ', x(1)
end program test_mkl_cdfnorminv
*** and provide all the instruction to compile , link and run, please.
i've tried implementing the Acklam algo, feeded with rand() , it provides numerical results but not gaussian distributed.
implicit none
interface
integer :: n
real(8) :: a(1)
real(8) :: y(1)
end interface
p(1) = 0.90d0
FUNCTION inv_normal_ack(p, mu, sigma) result(x)
! use of the instruction result
IMPLICIT NONE
REAL(8), INTENT(in) :: p, mu, sigma
REAL(8) :: x, z
REAL(8) :: q, r
! Coefficients for Acklam approximation
REAL(8), PARAMETER :: a1 = -3.969683028665376d0
REAL(8), PARAMETER :: a2 = 2.209460984245205d0
REAL(8), PARAMETER :: a3 = -2.759285104469687d0
REAL(8), PARAMETER :: a4 = 1.383577518672690d0
REAL(8), PARAMETER :: a5 = -3.066479806614716d-1
REAL(8), PARAMETER :: a6 = 2.506628277459239d-2
REAL(8), PARAMETER :: b1 = -5.447609879822406d0
REAL(8), PARAMETER :: b2 = 1.615858368580409d0
REAL(8), PARAMETER :: b3 = -1.556989798598866d-1
REAL(8), PARAMETER :: b4 = 6.680131188771972d-3
REAL(8), PARAMETER :: c1 = -7.784894002430293d-3
REAL(8), PARAMETER :: c2 = -3.223964580411365d-1
REAL(8), PARAMETER :: c3 = -2.400758277161838d0
REAL(8), PARAMETER :: c4 = -2.549732539343734d0
REAL(8), PARAMETER :: c5 = 4.374664141464968d0
REAL(8), PARAMETER :: c6 = 2.938163982698783d0
REAL(8), PARAMETER :: d1 = 7.784695709041462d-3
REAL(8), PARAMETER :: d2 = 3.224671290700398d-1
REAL(8), PARAMETER :: d3 = 2.445134137142996d0
REAL(8), PARAMETER :: d4 = 3.754408661907416d0
! Define breakpoints
REAL(8), PARAMETER :: plow = 0.02425d0
REAL(8), PARAMETER :: phigh = 1.0d0 - plow
IF (p <= 0.0d0 .or. p >= 1.0d0) THEN
WRITE(*,'(a)') "Error: p must be in [0 1]"
stop
END IF
! Compute z for standard normal
IF (p < plow) THEN
q = sqrt(-2.0d0 * log(p))
z = (((((c1*q+c2)*q+c3)*q+c4)*q+c5)*q+c6) / &
((((d1*q+d2)*q+d3)*q+d4)*q+1.0d0)
ELSE IF (p > phigh) THEN
q = sqrt(-2.0d0 * log(1.0d0 - p))
z = -(((((c1*q+c2)*q+c3)*q+c4)*q+c5)*q+c6) / &
ELSE
q = p - 0.5d0
r = q*q
z = (((((a1*r+a2)*r+a3)*r+a4)*r+a5)*r+a6)*q / &
(((((b1*r+b2)*r+b3)*r+b4)*r+1.0d0))
END IF
! Scale to given mean and std dev
x = mu + sigma * z
RETURN
END FUNCTION inv_normal_ack- Mark as New
You have already got the pieces that you need. Put the following lines into a Fortran source file, say, "tstcdf.f90":
implicit none
integer :: n
p(1) = 0.90d0
call vdCdfNormInv(1, p, x) ! x = F^{-1}(p)
Compile and link using the command
ifx -qmkl tstcdf.f90
and run using the command
./a.out
and you should see the output
out vdCdF 1.28155157
You do not need Acklam's code -- it does the same thing that the MKL routine vdCdfNormInv does.
