using ANY with derived type arrays?
alexismor
Hi everybody,
I was wondering if it was possible to use the ANY function with derived types. For example, I have defined a type called particle (which holds different integer quantum numbers of a particle) in a module called particle_module, along with interfaces for the assignment (=) and equivalence operators (==).
This is what I want to do:
program test
use particle_module
type(particle), dimension(3) :: p
type(particle) :: p_test
integer :: i
do i=1,3
p(i) = i !particle_module describes how to do this
enddo
p_test==4
if (ANY(p==p_test)) then
print*,'there is a match'
else
print*,'There is no match'
endif
stop
end
Is this possible? I was thinking that since I've allready defined how to do the equivalency operator in the particle_module this should be possible, but I can't get it to work. Is there some special trick?
Thanks!
No, this is not defined by Fortran. You are, of course, free to extend the ANY generic with your own implementation for your type.
