using hdf5
Luis_Solis
Hi
I have compiled a program using hdf5 (last pre-compiled binary from hdfgroup.org)
The project options are:
Fortran->General->additional include directories
.\\path2hdf5.mod
Linker->Options->Additional dependencies
.\\path2\\hdf5.lib .\\path2\\hdf5_fortran.lib .\\path2\\zlib.lib .\\path2\\szlib.lib
Linker->Ignores specific libraries
LIBCMT.LIB;libc.lib
The program compiles correctly, but are 28 warnings related with locally defined symbols (LNK4217 & 4049)
I accessed the page from microsoft http://msdn.microsoft.com/en-us/library/atww7hec.aspx.
They recommended that these warnings will disappear using the option /clr, It seems that is not available in version MVS 2008 shell.
I understand that I can not follow other indications when working with binary hdf5
If anyone has any suggestions, would be welcome
jarvusluntatintel
Luis
Are you just getting warnings and things run ok or can you not get hdf5 to run at all?
It took me some work, but I eventually got the hdf5 DLLs to run. My office security blocks me from downloading your attachment, so I can't see what the problems are. My project options have more *.mod files than you show andmore additional dependecies (although I am not sure that I really needed them all).
