Question about forall and where
tropfen
- FORALL and WHERE are posibillities to allow the compiler to execute inside statements in any order on more then one processor
--- is the optimitation standard in ivf (in both debug and release) or do i have to set specific compiler options?
- the following example is showing a procedure i would like to optimize
[fortran]real,dimension (200,200) :: rArray,rArray1,rArray2
integer :: ix,iy
rArray=-999.0
do ix=1,200 do iy=1,200 if ((abs(rArray1(ix,iy)--999.0)>0.0001).and.(abs(rArray2(ix,iy)--999.0)>0.0001)) then rArray(ix,iy)=rArray1(ix,iy)+rArray2(ix,iy) end if end do ! iy end do ! ix[/fortran]
Is there a way?
As far as i have understand a IF construct is not allowed in FORALL and WHERE does only have one element.
Thanks in advance
Frank
The original theory was that, yes, FORALL and WHERE, which are fancy array assignments, could allow parallelism. But the semantics were restrictive enough that it made it difficult to effectively paralleliize these constructs. As far as I know, Intel Fortran does not try to do so. (If it did, you would need /parallel and optimization.)
Fortran 2008 has added a "DO CONCURRENT" construct which is more straightforward to parallelize.
I suggest for now that you use OpenMP.
TimP
Why not start by correcting the loop nesting?
"If" your objective is to write something equally as optimizable but without IF, you have available MERGE, expressible as a rank 2 operation, or rank 1 inside an OpenMP elgible loop, or even rank 0 inside 2 loops.
TimP
Quoting tropfen
integer :: ix,iy
rArray=-999.0
Is there a way?
Why not begin by correcting the loop nesting? Even if it doesn't immediately enable vectorization, it's essential to enabling local data chunks for parallelization by OpenMP or otherwise.
j_clausen
DoesSteve's replymean that there is no advantages of using forall and where? I.e. I could just as well use standard do-loops and if-statements?
In my code I tend to use where and forall as much as I can, but maybe the only advantage is increased readability of the code for the trained eye.
Best Regards
j_clausen
TimP
I do think that forall may be the most readable way where a mask is in use, except that ifort generally requires IVDEP directive to optimize a single assignment under masked forall, and does not optimize multiple assignments under mask. It took me years to recognize that forall with multiple assignments means that all operations under one assignment are completed before beginning the next. Is that what you mean by a trained eye? It's difficult for a compiler to optimize multiple assignments in a forall, so for example
forall(i = i:n)
a(i) = b(i) + c(i)
d(i) = a(i) + b(i)
end forall
is not as easily optimized as a similar looking DO, nor any different from
a(1:n) = b(1:n) + c(1:n)
d(1:n) = a(1:n) + b(1:n)
which is a direct expression of the meaning.
ifort has been improving quality of code generation under where, but it's not entirely settled from version to version. where...elsewhere, when relevant, appears to improve readability but worsen compiler behavior. where implies generation of a temporary mask vector and the re-use of it in the elsewhere.
tropfen
Quoting tim18
forall(i = i:n)
a(i) = b(i) + c(i)
d(i) = a(i) + b(i)
end forall
i think the question was leading to an other direction.
What is faster:
[bash]integer :: i
real,dimension(100) :: f
do i=1,100
  f(i) = i*2
end do ! i
forall(i=1:100)
  f(i)=i*2
end forall[/bash]
And to improve the performance of one way which compiler options are additionally needed?
Frank
TimP
Quoting tropfen
Quoting tim18
What is faster:
[bash]integer :: i
do i=1,100
  f(i) = i*2
end do ! i
forall(i=1:100)
  f(i)=i*2
end forall[/bash]
You need a more complicated example before a choice of forall or DO should make any difference to performance, or for any compiler options beyond basic vectorization to matter. This loop isn't long enough for threaded parallel to work along with vectorization.
