29376 Discussions
vectorization of a type bound procedure
AThar2
I will attempt to ask without a working example. In case it requires let me know and I will try to work one out, however, you will realize that it is not straight forward
In my application I have realized that sometimes my !$OMP SIMD loop does not vectorize because of a procedure call to ...
call ptr% PROCEDURE_WITH_PASS(...)
, this subroutine has a one of its dummy argument declared as "class" since it got the PASS attribute when declared.  i.e.
Subroutine PROCEDURE_WITH_PASS( this , ..., )
class(type_dec), intent(inout) :: this
If I change the pass to NOPASS and declare the dummy argument as "type" (Because now the compiler allows me to do so) my SIMD LOOP does vectorize.
type(type_dec), intent(inout) :: this
what puzzles me is that I do have other examples where the the first example call does get vectorized. It is only when the procedure in my case get a bit more lenghty  OpenMP decides not to vectorize my loop when having the CLASS declaration.
PS: I do have the subroutines declared with an OMP declare simd.
I am not looking for an exact solution to my case, but what is your general experience on using OOP with vectorisation. Should I generally try to keep the lowest level of execution a normal routine. What I mean here is that when saying ` call ptr% proc`, then my proc routine has a call to another routine which is NOT type bounded and all dummy arguments would be explicit arrays?
For example
call ptr% proc
subroutine proc (this, ...)
class(t_da), intent(inout) :: this
call explicit_routine(this% array1, this% array2)
end subroutine proc
subroutine explicit_routine
real, contiguous :: a1(:), a2(:)
end  subroutine
Juergen_R_R
Valued Contributor II
This might be a safeguard of the compiler/optimizer for the case of DT-TBP because they might be overwritten, and in the vectorized execution the compiler might not be able to determine at compile time that all routines will be of the same type. But this is just a guess. Did you compare with a different compiler?
FortranFan
AT90 wrote:
.. what puzzles me is that I do have other examples where the the first example call does get vectorized. It is only when the procedure in my case get a bit more lenghty  OpenMP decides not to vectorize my loop when having the CLASS declaration. ..
Can you show a working example where the call is not vectorized?  And preferably a case where you think it is (but it actually may not be!).
