- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
Hi
find this little test program with two issues:
MODULE m_common
USE, intrinsic :: iso_fortran_env
implicit none
integer, parameter :: ip = INT32
integer, parameter :: rp = REAL64
END MODULE m_common
MODULE m_vec_tens
USE m_common
implicit none
TYPE vec2d
real(rp) :: x = 0._rp
real(rp) :: y = 0._rp
CONTAINS
procedure, pass(self) :: equal_vec2d
procedure, pass(self) :: add_vec2d
procedure, pass(self) :: sub_vec2d
procedure, pass(self) :: dotprod_vec2d
generic :: assignment(=) => equal_vec2d
generic :: operator(+) => add_vec2d
generic :: operator(-) => sub_vec2d
generic :: operator(.dotprod.) => dotprod_vec2d
END TYPE vec2d
CONTAINS
PURE ELEMENTAL SUBROUTINE equal_vec2d( self , from )
class(vec2d), intent(inout) :: self
class(vec2d), intent(in ) :: from
self%x = from%x
self%y = from%y
END SUBROUTINE equal_vec2d
PURE ELEMENTAL FUNCTION add_vec2d( self , from ) RESULT( this )
class(vec2d), intent(in) :: self , from
type(vec2d) :: this
this%x = self%x + from%x
this%y = self%y + from%y
END FUNCTION add_vec2d
PURE ELEMENTAL FUNCTION sub_vec2d( self , from ) RESULT( this )
type(vec2d) :: this
this%x = self%x - from%x
this%y = self%y - from%y
END FUNCTION sub_vec2d
PURE ELEMENTAL FUNCTION dotprod_vec2d( self , from ) RESULT( dotprod )
real(rp) :: dotprod
dotprod = self%x * from%x + &
self%y * from%y
END FUNCTION dotprod_vec2d
END MODULE m_vec_tens
MODULE m_field
USE m_vec_tens
TYPE field
type(vec2d), allocatable :: v1(:)
type(vec2d), allocatable :: v2(:)
END TYPE field
END MODULE m_field
PROGRAM test_vec_tens
USE m_field
implicit none
integer(ip), parameter :: n = 100000
integer(8) :: count , count_scale , count_max
integer(ip) :: i , j , k , nt
real(rp) :: time , rate
real(rp), dimension(n) :: s1 , s2 , s3 , s4 , s5 , s6
type(vec2d), dimension(n) :: v1 , v2 , v3
type(field) :: f
call random_number( s3(1:n) )
call random_number( s4(1:n) )
call random_number( s5(1:n) )
call random_number( s6(1:n) )
call random_number( v2(1:n)%x )
call random_number( v2(1:n)%y )
call random_number( v3(1:n)%x )
call random_number( v3(1:n)%y )
call system_clock( count , count_scale , count_max )
rate = real( count_scale , 8 )
time = real( count , 8 )
do nt = 1,1000
s1(1:n) = s3(1:n) + s4(1:n)
s2(1:n) = s5(1:n) + s6(1:n)
s3(1) = s2(n)
s5(1) = s1(n)
end do
write(6,*) ( real( count , 8 ) - time ) / rate
! LOOP BEGIN at test_vec_tens.f90(49,28) inlined into test_vec_tens.f90(166,25)
! remark #25096: Loop Interchange not done due to: Imperfect Loop Nest (Either at Source or due to other Compiler Transformations)
! remark #25451: Advice: Loop Interchange, if possible, might help loopnest. Suggested Permutation : ( 1 2 ) --> ( 2 1 )
! remark #15344: loop was not vectorized: vector dependence prevents vectorization
! remark #15346: vector dependence: assumed FLOW dependence between 251.Y line 56 and 251.Y line 45
! remark #15346: vector dependence: assumed ANTI dependence between 251.Y line 45 and 251.Y line 56
! LOOP BEGIN at test_vec_tens.f90(166,7)
! remark #25427: Loop Statements Reordered
! remark #25438: unrolled without remainder by 2
! LOOP END
! LOOP END
do nt = 1,1000
v1(1:n) = v2(1:n) + v3(1:n)
v2(1)%x = v1(n)%y
v2(1)%y = v1(n)%x
end do
allocate( f%v1(n) )
allocate( f%v2(n) )
! test_vec_tens.f90(187): error #6866: Dotted string is neither a defined operator nor a structure component. [DOTPROD]
! s1(i) = f%v1(i) .dotprod. f%v2(i)
! compilation aborted for test_vec_tens.f90 (code 1)
! do i = 1,n
! end do
v1(1:n) = f%v1(1:n)
v2(1:n) = f%v2(1:n)
do i = 1,n
s1(i) = v1(i) .dotprod. f%v2(i)
end do
do i = 1,n
s1(i) = f%v1(i) .dotprod. v2(i)
end do
END PROGRAM test_vec_tens
with my configuration:
ifort --version ifort (IFORT) 16.0.1 20151021 Copyright (C) 1985-2015 Intel Corporation. All rights reserved. Linux gmmpc209 4.2.0-35-generic #40-Ubuntu SMP Tue Mar 15 22:15:45 UTC 2016 x86_64 x86_64 x86_64 GNU/Linux
first, it seams that there is a bug in compiler considering two allocatable array of vec2d type in field type container when I want to use the generic binding operator .dotprod.
If I copy the array to a local array, no problem in both directions
If I use en interface operator to overload .dotprod. rather than generic binding, no problem at all
secondly, I'm not a expert but I'm little confused with vectorization of my overloaded operators
time computations are very similar if I do not use -ipo optimization flag with other -fast flags for example and very different with
any advices or comments ?
thanks,
Fred Couderc
링크가 복사됨
- 신규로 표시
- 북마크
- 구독
- 소거
- RSS 피드 구독
- 강조
- 인쇄
- 부적절한 컨텐트 신고
I have reproduced the error on the operator and open a defect report DPD200410721
Xiaoping Duan
Intel Customer Support
