Hi guys,
I have Visual Studio 2013 installed in my computer. I installed Intel parallel studio xe composer trial version. I noticed intel Visual Fortran was not one of the programming languages on the templates.
Is it that Visual Studio 2013 community doesnt support Intel Visual Fortran programming language?
VS2013 Community does support Intel Visual Fortran versions that support VS2013. Which version did you install? See if this link helps.
Thanks Steve, am using the Intel parallel xe composer 30 trial version. Everything got installed successfully but I noticed Intel Visual Fortran wasn't list amongst the list of programming languages on the left pane.
Assuming that you installed the 2016 version, it should work. Try the link I provided above.
