visual studio 2022
beppe555
The project is done with a set of fortran files, that are the main part of the code. So, the VS project was built as a console app in Fortran.
The project is completed with some C files, that must generate some .mod files to interface some fortran calls and, more, a resource file (.rc).
The whole project has been well tested for years with other IDE systems and other compilers.
As an example, the Winteracter IDE handles the same project as a unique list of files, then the IDE itself chooses the correct compiler following the usual suffix conventions.
For what I have understood, it should be possible to force VS to apply the C++ compiler to each ".c" or ".cpp" file instead of Ifort, but the properties panels does not show any way to do this.
Also tried to use these C files in a separate project, build the .mod files separately and then trying to load them in the fortran project: apart from the inconvenience of two separate environments, I found no any way to ask the fortran compiler for loading these interfaces.
Someone may help? Many thanks in advance. BP
Devorah_H_Intel
