29335 Discussions
How to get Intel Visual Fortran Composer 2013 XE
CoryG
I'm joining a project where the compiler currently in use is Intel Visual Fortran Composer 2013 XE. We're looking to update soon, but just to get started, I need that specific version. How can I get access to that?
mecej4
That compiler version is a decade old, and is probably not available, even if you had purchased a license for that specific version in the past.
The good news, however, is that most projects can be built and run fine with the current version of the compiler.
My suggestion: download and install the current compiler, and try building your project. If you run into problems, you can come back here with reports on those problems and get them resolved.
