visual studio not responding
tiho
While debugging the visual studion crashes (not responding) with the error
Problem signature:
Problem Event Name: APPCRASH
Application Name: devenv.exe
Application Version: 9.0.21022.8
Application Timestamp: 47317b3d
Fault Module Name: ForDbgEE.DLL
Fault Module Version: 11.1.5178.2008
Fault Module Timestamp: 4b5f093d
Exception Code: c0000005
Exception Offset: 000110cb
OS Version: 6.1.7600.2.0.0.256.48
Locale ID: 1033
Additional information about the problem:
LCID: 1033
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\\Windows\\system32\\en-US\\erofflps.txt
any hints for how to resove this?
Jeffrey_A_Intel
Can you supply (or confirm)the following information:
  • Describe what you do to cause the problem.
  • Which version of Windows?
  • Which version of Visual Studio? It appears to be VS2008 but please confirm.
  • Which version of IVF? It looks likeIVF 11.1 update #5 or update #6. Again, please confirm.
Since you aren't using the latest version of IVF 11.1, can you upgrade to update #7 and see if that solves the problem.
tiho
Windows 7, VS2008,
Intel Visual Fortran 11.1.065 [Intel 64].
tiho
What appears to be casuinbg the problem is putting a breakpoint. It works fine without the break point.
tiho
when I go line by line it crashes when allocating an array of composite type - outside that subroutine breakpoints / and debugging all seems fine even after the allocation
tiho
I updated IVF to update #7 - still crashing
Problem signature:
Fault Module Version: 11.1.5387.2008
Fault Module Timestamp: 4c62ee5b
Exception Offset: 0001107b
Locale ID: 1033
LCID: 1033
C:\Windows\system32\en-US\erofflps.txt
tiho
any further hints?
Wendy_Doerner__Intel
Valued Contributor I
Please post a zipped up version of the solution to this issue so we can reproduce here.
Wendy
Attaching or including files in a post
tiho
I am not sure if I understand your suggestion. The code is proprietary so I can not post it in the public domain.
I will take this post priviate with my next message and if you post there only you and I will be able to see it.
I am afraid without a test case we can not diagnose the problem.
Wendy
tiho
I have found a solution to this problem - clearing up the "watch variables" window resolves the crashes. But even that is a bit tricky because sometimes it crashes before you can clear up the watch window.
Is there a way to clear the watch window before I go into debugging?
