void pointer?
Julian_H_
I have a problem I would like to solve but somehow I struggle.
I have different types defined:
! Type KUGS ([KUG]el cheibe)
	TYPE, PUBLIC :: typeKUGS
		CHARACTER(4) :: cIdent	= 'KUGS'
		CHARACTER(4) :: cANam	= ''
		CHARACTER(4) :: cMant	= ''
		CHARACTER(4) :: cMat	= ''
		CHARACTER(4) :: cSpaw	= ''
		TYPE(typeKOOS) :: KOOS_P1, KOOS_P2
		REAL(8) :: rR1 = -1._dp, rR2 = -1._dp
		REAL(8) :: rS1 = -1._dp, rS2 = -1._dp
		REAL(8) :: rRKug
		CONTAINS
			PROCEDURE, PUBLIC::setKUGS => setKUGS_sub
	END TYPE typeKUGS
	! Type TORS ([TOR]us cheibe)
	TYPE, PUBLIC :: typeTORS
		CHARACTER(4) :: cIdent	= 'TORS'
		REAL(8) :: rRtor
		CONTAINS
			PROCEDURE, PUBLIC::setTORS => setTORS_sub
		END TYPE typeTORS
Now I want to define the type typeVAM1 which should have a pointer pointing to a typeKUGS, typeTORS or some other type, but from what I know a pointer always have to be of the same variable type as the target
! Type VAM1
		TYPE, PUBLIC :: typeVAM1
			CHARACTER(4) :: cIdent	= 'VAM1'
			CHARACTER(4) :: cVNam	= ''
			CHARACTER(1) :: cVTyp	= ''
			CHARACTER(1) :: cMIA	= ''
			CHARACTER(4) :: cVA		= ''
			CHARACTER(4) :: cPA		= ''
			CHARACTER(4) :: cMV		= ''
			CHARACTER(4) :: cVTNa	= ''
			REAL(8) :: rFBAln		= -1._dp
			REAL(8) :: rFBAls		= -1._dp
			REAL(8) :: rEckD		= 0._dp
			REAL(8) :: rArov		= -1._dp
			REAL(8) :: rSFak		= -1._dp
			VOID, POINTER :: pKVNa	! this should point to typeKUGS or typeTORS etc...
			REAL(8) :: rAriv		= 0._dp
			INTEGER :: iMaNv		= 0
		CONTAINS
			PROCEDURE, PUBLIC::setVAM1 => setVAM1_sub
		END TYPE typeVAM1
Does someting like a void pointer exist or someone has an other idea to solve this?
Steve_Lionel
A couple of options. a CLASS(*) pointer can point to any type. It carries the type info with it. Another option is to use type C_PTR from ISO_C_BINDING, use C_LOC to assign it and C_F_POINTER to "cast" to the desired type. An issue with CLASS(*) is that if you want to use the pointer you will have to do so within a SELECT TYPE construct.
Steve_Lionel
FortranFan
As shown in the original post, the two types (typeKUGS and typeTORS) look the same, only the values of components seem to differ, implying two object instances of the same type.  Can you not look into this and check whether a TYPE(..) component in typeVAM1 would be a better choice?
Julian_H_
Yeah the example is simplified, my fault. The other types are looking totally different.
Julian_H_
Thanks once again. I will give  the class(*) a try.
Trying:
	SUBROUTINE findSuperelement_sub(this, cANam, lIsFound, SU)
		IMPLICIT NONE
		CLASS(typeSIP), INTENT(IN) :: this
		CHARACTER(4), INTENT(IN) :: cANam
		LOGICAL, INTENT(OUT) :: lIsFound
		CLASS(*), POINTER, INTENT(OUT) :: SU(:)
        TYPE(typeKOZE),  TARGET :: KOZE
		lIsFound = .FALSE.
		CALL this%findKOZE(cANam, lIsFound, KOZE)
		IF (lIsFound) THEN
            ALLOCATE(TYPE(typeKOZE)::SU(1))
            SELECT TYPE(SU)
                TYPE IS (typeKOZE)
                    SU(1) => KOZE
                CLASS DEFAULT
                    WRITE(*,*) 'eleganter Error'
            END SELECT
			RETURN
        END IF
		IMPLICIT NONE
		lIsFound = .FALSE.
		IF (lIsFound) THEN
            SU => KOZE
			RETURN
        END IF
	END SUBROUTINE findSuperelement_sub
I tried the concept but I guess I still do not understand it fully. This is my try. The pointer pKOZE => KOZE is pointing correctly, but the allocaten of the CLASS(*) SU is not working. Any suggestions what I am doing wrong?
I found online this example
class(*), pointer :: v1, v2(:)
type(person), target :: p1
real, pointer :: r1(:)
v1 => p1
allocate(real :: v2(10))
select type (v2)
type is (real)
r1 => v2
class default
stop 'Error in type selection'
end select
SOURCE: http://www.training.prace-ri.eu/uploads/tx_pracetmo/AdvFTN_handout.pdf
so the select type construct has to be used just in the case I have to allocate an array?
IanH
The first subroutine in #5 should not compile.  It has syntax that attempts to pointer assign to an array element.  Array elements in Fortran are never pointers.
In the first subroutine, `SU` is a pointer array.  It can be pointed at other arrays - `su => some_other_array`.
If you want an array that has a pointer for each element, then the array needs to be of a derived type with a pointer component.
type :: t
  ! Pointer to a scalar of any type.
  class(*), pointer :: item => null()
end type t
type(t) :: array(2)
type(x), target :: some_scalar
type(y), target :: another_scalar
array(1)%item => some_scalar
array(2)%item => another_scalar
You don't have to use select type to allocate a polymorphic array - depending on the language revision you are targeting (and whether your compiler supports those revisions) other options exist, including perhaps just using an assignment statement.
It isn't totally clear to me what you are trying to do - consider providing more explanation.
Julian_H_
type :: t
end type t
type(t) :: array(2)
By the subroutines in #5 I just try to understand the concept which Lionel explained. His answer was quite short but pointed in the right direction, so I searched for more information and found the last example in #5. I tried to copy the concept . The subrouteine findSuperelement_sub is not complete yet. cANam is a unique string. For this string is searched in different types (for now just all Objects of typeKOZE but there will be more types). Because of this is neccessary that the subroutine findSuperelemnt_sub has the capability to return CLASS(*) because in the subroutine itself its determiend which Object type will be returned.
For this "Superelement" is searched so I can point from the typeVAM1 to it, thats what I wrote in my initial post.
