29414 Discussions
vs shell 2010: parentheses matching highlight
Luis_Solis
Hi
Is there any option to highlight matching parentheses in vs shell 2010?
I've tried with tools->options->environment
I've found brace matching highlight, but not parentheses matching
No, there isn't. What we do have is matching block begin and end constructs (IF..END IF, DO..END DO, etc.)
jimdempseyatthecove
Louis,
Most (if not all) of the IDE "experience" is implimented using Visual Basic scripts. If you have time on your hands, you might try to locate the VB scripts used when editing C/C++ then look in the script for the functions that do the () matching, as well as {}, []. You should be able to copy these VB functions into the IVF scripts then check where highlighting calls are made and add the new functions to the list.
Jim Dempsey
