I am using , Intel(R) Visual Fortran Composer XE 2013 Update 3 Integration for Microsoft Visual Studio* 2010, 13.0.3624.2010, Copyright (C) 2002-2013 Intel Corporation.
Looking at a new OPEN GL project and adding certain existing source files causes VS to crash and burn. Reading some other posts if I set:
Tools > Options > Text Editor > Fortran > Advanced and set Disable Database to True. AND also turn of "enable outlining" it does not crash.
I have attached a sample. I really like outlining :-( is there a fix? I suspect changeing a line or two in the source might make the problem go away.
I have attached a sample file
Slight correction the work around above worked with adding the problem files to the project. But in the particular case of the file attached, I still cannot open it in a vs edit window without a crash. The file opens, displays and then after a short delay we crash and burn. I can edit in notepad externally OK.
>>>causes VS to crash and burn.>>>
What do you mean by writing burn ?
Just and expression for terminate in and undesirable way abit bit like crashing a plane full of fuel :-(
Ok I got it too seriously:)
It is doing my head in! I am working and the project In VS and every time I want to reffer to the interface and click on one of the affected files (rather then viewing in notepad externally). Bang exit , no saves :-(
I can reproduce this - thanks. We've had several other similar issues. We'll fix it as soon as we can. In the meantime, you'll need to disable the advanced options. Issue ID is DPD200245401.
which ones? All false except disable database which is true
"I have already done Tools > Options > Text Editor > Fortran > Advanced and set Disable Database to True. AND also turn of "enable outlining"
The developers tell me they have fixed this problem for the next update. A workaround:
Find the following line
TYPE(C_PTR), BIND(C), PUBLIC, PROTECTED :: GLUT_STROKE_ROMAN, &
and change it to
TYPE(C_PTR), PUBLIC, PROTECTED, BIND(C) :: GLUT_STROKE_ROMAN, &
@steve I see a large amount of mangled html in your post, whatever you cut n pasted does not quite work....
I edited it.
@steve your post is gone and I now have a legible post... I will try that.
Thanks, you don't know how much that help!
