29578 Discussions
vs2010 shell crash, text editor settings
andrew_4619
I am using , Intel(R) Visual Fortran Composer XE 2013 Update 3 Integration for Microsoft Visual Studio* 2010, 13.0.3624.2010, Copyright (C) 2002-2013 Intel Corporation.
Looking at a new  OPEN GL project and adding certain existing source files  causes VS to crash and burn. Reading some other posts if I set:
Tools > Options > Text Editor > Fortran > Advanced and set Disable Database to True. AND also turn of "enable outlining" it does not crash.
I have attached a sample. I really like outlining :-( is there a fix? I suspect changeing a line or two in the source might make the problem go away.
I have attached a sample file
andrew_4619
Slight correction the work around above worked with adding the problem files to the project. But in the particular case of the file attached, I still cannot open it in a vs edit window without a crash. The file opens, displays and then after a short delay we crash and burn. I can edit in notepad externally OK.
Bernard
Valued Contributor I
>>>causes VS to crash and burn.>>>
What do you mean by writing burn ?
andrew_4619
Just and expression  for terminate in and undesirable way abit bit like crashing a plane full of fuel :-(
Bernard
Ok I got it too seriously:)
andrew_4619
It is doing my head in! I am working and the project In VS  and every time I want to reffer to the interface and click on one of the affected files (rather then viewing in notepad externally). Bang exit , no saves :-(
I can reproduce this - thanks.  We've had several other similar issues. We'll fix it as soon as we can. In the meantime, you'll need to disable the advanced options. Issue ID is DPD200245401.
andrew_4619
which ones? All false except disable database which is true
"I have already done Tools > Options > Text Editor > Fortran > Advanced and set Disable Database to True. AND also turn of "enable outlining"
The developers tell me they have fixed this problem for the next update.  A workaround:
Find the following line
TYPE(C_PTR), BIND(C), PUBLIC, PROTECTED :: GLUT_STROKE_ROMAN,        &
and change it to
TYPE(C_PTR), PUBLIC, PROTECTED, BIND(C) :: GLUT_STROKE_ROMAN,        &
andrew_4619
@steve I see a large amount of mangled html in your post, whatever you cut n pasted does not quite work....
I edited it.
andrew_4619
@steve your post is gone and I now have a legible post... I will try that.
andrew_4619
Thanks, you don't know how much that help!
