-warn interface and derived types
Chris_Payne
RHEL 5.4, 64-bit. Compiler version 12.0.3.
I have a derived type, which is used to pass an argument from a program to a subroutine.
Here is the definition of the derived type, which resides in x.crd
type x_t
integer*4 i
end type
The subroutine, in s.for, is:
subroutine s(x)
implicit none
include 'x.crd'
type(x_t)::x
type *, x
end
And the main program, in m.for, is
program m
implicit none
include 'x.crd'
type(x_t)::x
call s(x)
end
I have IFORTCFG set to nothing. I run these commands, and get the error shown:
$ ifort -c -warn interface s.for
$ifort -c -warn interface m.for
m.for(5): error #6633: The type of the actual argument differs from the type of the dummy argument.
call s(x)
compilation aborted for m.for (code 1)
Here is the generated interface block, from s__genmod.f90
!COMPILER-GENERATED INTERFACE MODULE: Tue May 10 14:25:57 2011
MODULE S__genmod
INTERFACE
SUBROUTINE S(X)
TYPE X_T
INTEGER(KIND=4) :: I
END TYPE X_T
TYPE (X_T) :: X
END SUBROUTINE S
END INTERFACE
END MODULE S__genmod
What is the compiler complaining about?
You have two different X_T types that have the same components, but they are not the same type in Fortran's eyes. Yes, this will work if you don't have generated interface checking, even though it is technically non-standard, but with an explicit interface, generated or actual, there's no way to represent this. The Fortran language would have you put X_T in a module and USE that.
mecej4
At first encounter this message is perplexing, but it follows from the way that the Fortran Standard specifies type compatibility.
Section 5.1.1.1 of the standard says:
8 Where a data entity is declared explicitly using the TYPE type specifier, the specified derived type shall
9 have been defined previously in the scoping unit or be accessible there by use or host association.
That may seem to shed little light on the issue, so consider this reinterpretation in Metcalf, Reid and Cohen's book, 'Fortran 95/2003 Explained':
Different declarations of a TYPE, even if the declarations are identical, do not create argument-compatible types (with few exceptions). That is why it is necessary to create a single definition, in a module if necessary, and USE that definition wherever it is needed.
Exactly. BTW, Metcalf/Reid/Cohen have a new edition of their book out that covers Fortran 2008. They ran out of room for numbers so they just call it "Modern Fortran Explained" now. I got a copy yesterday.
mecej4
I received my copy in 2006 as a reward for answering an Intel online survey on Fortran. With its reasonable size and concise explanations, for me it lowered the barrier to making the transition from F77 to F95.
