29359 Discussions
/warn:interfaces /gen-interfaces
ocean
Steve,
We are using IVF 9.1.023 with VS2005 and are having some problems with the compiler setting /warn:interfaces /gen-interfaces. Our application compiles fine as long as this two compiler settings are disabled. If enabled, the compilerexits with an error message.
Has this problem been fixed in the latest IVF update and from where can I get that update.
Manny
Steven_L_Intel1
It is not possible to know if "this problem" has been fixed without a test case. We have fixed a number of issues with symptoms similar to that, but there are various causes. I don't know if your particular issue is one that has been previously addressed.
To get the current update, log in to the Intel Registration Center and select Product Downloads. 9.1.034 is current, but a new update will be available in the next few days.
ocean
Steve,
I'll get the latest update andwill give it a try.
Manny
