29653 Discussions
why a derive type contains allocatable array would finalize twice when use constructer
dumashu
[fortran]MODULE  mytype_module
    integer,save :: icount = 0
    TYPE  mytype
       integer,allocatable :: val(:)
    contains
        final :: final
    END  TYPE
    INTERFACE  mytype
        MODULE  PROCEDURE  int_to_mytype
    END  INTERFACE
    !  Operator  definitions  etc.
CONTAINS
    FUNCTION  int_to_mytype(i) result(x)
        TYPE(mytype)        :: x
        INTEGER,INTENT(IN)  ::  i
        allocate(x%val(i)) ; x%val = 1
        print *,'get 1'
    END  FUNCTION
    subroutine final(x)
        type(mytype) :: x
        icount = icount + 1
        print *,'finalized'
    end subroutine
END MODULE
PROGRAM  example
    USE  mytype_module
    TYPE(mytype) ::  y
    y = mytype(10)
    print *,'finalize count',icount
END PROGRAM[/fortran]
thne result is:
finalized
finalized
finalize count 2
compiler xe 2011 update1 win 64
if change the component array from allocatable to pointer, then result would be once.
dumashu
if i define assignment
interface assignment(=)
module procedure assb
END INTERFACE
the result is only finalize 1
if i change allocatable component to pointer, the result is 0.
the fortran 2003 reference said
If an executable construct references a function, the result is nalized after execution of the innermost executable construct containing the reference.
but is seems that if a derive type does not have a allocatable component, the function result would not be finalized.
Andrew_Smith
Valued Contributor I
The function int_to_mytype is creating one instance of mytpe then assinging it to your local variable y which is a second instance. These two instances both require finalizing.
When assigning a pointer you only have one instance.
dumashu
TYPE mytype
integer :: len
! integer,allocatable :: val(:)
integer,pointer :: val(:)
contains
final :: final
! procedure :: assb
! generic :: assignment(=) => assb
END TYPE
END INTERFACE
INTERFACE mytype
END INTERFACE
CONTAINS
subroutine assb(a,b)
class(mytype),intent(inout) :: a
class(mytype),intent(in) :: b
a % val => b%val
end subroutine
TYPE(mytype) :: x
! allocate(x%vp(i)) ; x%vp= -1
END FUNCTION
subroutine final(x)
type(mytype) :: x
icount = icount + 1
print *,'finalized'
end subroutine
END MODULE
PROGRAM example
USE mytype_module
TYPE(mytype) :: y
type(mytype) :: z
integer,allocatable :: b(:)
b = [1,2,3]
y = mytype(10)
z = y
z = int_to_mytype(10)
END PROGRAM
the result is
finalize count 0
finalize count 0
finalize count 0
[/fortran]
so why int_to_mytype does not create a instance when then component of mytype is a pointer instead of a allocatable array
