29649 Discussions
why dose the efficiency decrease when many allocatable arrays are declared in modules?
Jinbin
I wrote two different codes doing the same thing. In the older version, I only declared some variables but no arrays in modules. I used openmp to  parallelize it. In this case, the code works well and is successfully accelerated. However, the new version code cannot be accelerated. In this version, I declared some allocatable arrays, which are only assigned before I run any parallelized codes, in modules.  In the new version, the performance is lower then the single thread case after parallelized. Should I avoid to use allocatable arrays in module? Or, there are some thing should be set such as environment variables.
jimdempseyatthecove
Something else is going on. Please use VTune on both versions of the code and look for the overhead (and lack of threading).
Jim Dempsey
