write to console
hkausl
I have a dummy console application
program test
write ( *,* ) ' hallo'
call exit
end
On the write statement to stdout I get an error, that I can't writ to a file in my users-directory. It seems, that the stadout isn't set to console. What have I to do to make this work, becoause normally I work with conolse applications. With Compaq Fortran this worked.
TimP
I've never seen any problem when trying such a test by compiling from command line. If you are using Visual Studio GUI, possibly you didn't succeed in choosing a console application?
hkausl
It's done in Visual Studio 2008 as a console application. Woth command-line I have the same problem.
Steven_L_Intel1
Please attach a screenshot of the error.
hkausl
Now I changed my user to be an administrator. Then write (*,* ) writes to the file c:\diocumen....local settings\temp\ramis_fort_print.log. The direcory is not my user-directory. The write (*,*) output is written exactly to this file. When I'm not an administrator, I can't write to this file and get an error.
Then I ichanged the statment ot write ( 6,*) , the filename changed to ramsis_fort6.log.When I look tho the environment, there are 2 variables set, FORT6 and FOR_PRINT which look exactly to these 2 files.
Then I tried write (0,*) and this seems to work. I have to test it onece more, when I have installed version 4. .
PS. Perhaps it has something to dto with the Intel Compiler version 8 which is also installed on my machine.
hkausl
So I tried it with version 4, same result. Write (*,* ) wants to write to a file which is set with the variable FOR_PRINT.
When I code write ( 0,*) then it works.
For reading I have to code read (*,*) this works too.
In my opinion write (*,*) is fortran standard, why does it not work?
mecej4
> ...is Fortran standard, why does it not work?
You have answered this question yourself. The culprit environment variables are not normally set on a Windows system. Someone set them on your system.
As many compilers do, IFort implements several extensions to the Fortran Standard and other features that are requested by users. Among these is redirection of standard I/O to named files using environmental variables. A list of these variables is available in the IFort documentation under Compiler Run-Time Environment Variables.
An earlier installation on your machine has set some of these variables, causing the behavior that you described. Simply remove the culprit SET statements in batch files or using the System_Properties:Advanced:Environment_Variables control panel. Alternatively, set these variables to NULL before running your applications.
Arjen_Markus
write(*,*) and read(*,*) are indeed part of the Fortran standard and have been so since at least
FORTRAN 77. What is not part of the standard is what these preconnected units actually represent.
All current operating systems I know allow you to redirect the output to the screen to a file and to
redirect input from the keyboard to a file. This may even be fed to a different program or coming
from a different program. These are features that are completely beyond the control of the compiler.
The environment variables the OP has encountered are yet another way the preconnected units can
be influenced. (I was not aware of these, it is good to know).
Arjen
hkausl
I deleted the 2 system variables and now it woks. Thanks.
