x64 build for project/s
MiB1980
I am building a solution in x64 configuration. The solution has 5 projects. It just builds one project and gives the error :
Project not selected to build for this solution configuration
Which option do I need to modify for this ?
I've seen this happen sometimes. Select Build > Configuration Manager. You'll probably see that some of the projects don't have an x64 configuration. Use that dialog to add one.
MiB1980
Thanks Steve... Some of the projects didnt have an x64 config. Worked after that...
