Intel® Gaudi® AI Accelerator
Support for the Intel® Gaudi® AI Accelerator
28 Discussions
Does multi-node works?
fmohamm
I am working on making the multinode run on Gaudi2 (v 1.20.0) by following the readme file here: https://github.com/HabanaAI/Megatron-LM/tree/main.  I am working with containers.  Even after multiple trials, I am not able to get the multi node code running on two gaudi nodes that are avaialable to me.
Is the readme file updated for latest
James_Edwards
The documentation should be up to date. However, to debug your issue I will need more information regarding what you are trying to accomplish and the errors you are seeing. Please provide information on the example you are trying to run, how you are executing the example to run multi-node and the errors you are receiving.
fmohamm
I have two bare-metal gaudi machine, and I am trying the script   from https://github.com/HabanaAI/Megatron-LM/blob/1.20.0/examples/llama/README.md#setup  and https://docs.habana.ai/en/latest/Installation_Guide/Driver_Installation.html#driver-installation.
Both the machines are connected from same jump server. During the setup, I am trying to check the accelerator interface status using the following commands. I see that the status on one machine is "up" while the status on other machine is "down".
/opt/habanalabs/qual/[gaudi3,gaudi2,gaudi1]/bin/manage_network_ifs.sh --up
 /opt/habanalabs/qual/[gaudi3,gaudi2,gaudi1]/bin/manage_network_ifs.sh --status
Is there any steps that are missing on README?
James_Edwards
The customer has given me the following output on the "bad" node:
/opt/habanalabs/qual/gaudi2/bin/manage_network_ifs.sh --status
accel0
3 ports down (8, 22, 23)
accel1
accel2
accel3
accel4
accel5
accel6
accel7
I requested that he contact the lab admin to make sure the Gaudi platform has been wired to the accelerator network correctly.
James_Edwards
Is there any status on this issue? Has the problem been resolved?
fmohamm
We built another machine from scratch. This new machine also has the same issue.  Exactly same error that I was getting in the previous machine.
James_Edwards
Is the machine you built from scratch linked into the same switch used on the accelerator network?
fmohamm
Talked to the IT and they said that the machines are on different switch. How the ports status being `down` is related to being on different switch?
James_Edwards
IT basically didn't answer the question, as the new machine could be on the switch that was used previously, or it could be on a different one. If the "new" system is connected to the switch correctly, IT should see the illuminated LED indicator light, showing that the connection is working. If they are on, the ports for the system should be up. If they aren't, something is wrong with the switch or the cabling.
Whatever the case, if the two systems are on a different switch and those switches are not connected through a "spine" switch the boxes will not communicate with one another.
