Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Cannot display render target (DX12)
Benoît_Vimont
I'm using GPA 2016 2016 R1 (16.1.282273) with DX12 and I cannot display the content of the render target (backbuffer). Should I do something special so as to be able to display render target contents in the frame analyser?
Benoît_Vimont
I updated to GPA 16.1.282401 and still have the problem, but I just noticed that I had D3D debug layer enabled.
If I capture without D3D debug layer enabled, I don't have the "failed to load" message anymore for the backbuffer (but still for the depthstencil), and I have corrupted render target content instead.
What I expected :
Seth_S_Intel
Hi Benoit,
Sorry that you are running into this issue.
if you could copy paste your Graphics monitor -> about dialog here that would be great.
Also, If you could private message me your application and/or frame file, I can start the defect filing process.
Thanks!
Seth
Benoît_Vimont
Windows 10 build 10586, 64-bit DEP enabled
Num Processors: 12
Memory: 32694MB
System BIOS: Hewlett-Packard J61 v01.14 (07/17/2012)
Video BIOS: 02/19/14
Driver 0:
     Device: AMD Radeon R9 200 Series
     Provider: Advanced Micro Devices, Inc.
     Date: 3-21-2016
     Version: 16.150.2211.0
     VendorId: 1002
     ProductId: 6810
     Stepping: 0
     No support for GPA Instrumentation
Install directory: C:\Program Files\IntelSWTools\GPA_16.1\
Version: 16.1.282401
Current user is in Administrators group: YES
Current Graphics Performance Analyzers 2016 R1 (16.1.282401)
Secure Boot/Trusted Boot is Disabled
"Auto-detect launched applications" is On
I'm sending you the capture file by private message and see if I can send you the application.
Benoît_Vimont
Done! I have sent you the GPA capture file and test application by private message.
Thanks for your help,
Benoît.
Seth_S_Intel
Hi Benoit,
I was able to reproduce this issue on my side with the frame file.  I also sent you another private message.
Best,
Seth
