Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Capture failed: Unsupported D3DFormat
LLiu22
Dear sir, We are writing a rendering software with D3D9. By using GPA, the monitor can successfully show FPS on the frame. But when using Ctrl+Shift+C to capture a frame, it sometimes report: Unsupported D3DFormat: 0x9C. The failure rate are very high, about 9/10. Yes, it occasionally works, to produce a valid frame captired file. We really confused by this. Please give us some clue to identify the problem! By the way, what the value, 0x9C, means? Best regards, Lan
Ryan_G_Intel
Hi Lan L,
First of all, thank you for deciding to use GPA!
It is difficult to say exactly what the issue is without looking at the software you are writing.
Is it possible to get a sample of the software to see if there is an issue we need to look at?  Also, is it possible to get a copy of the 'About' dialog from GPA Monitor?  To get this - Make sure Graphics Monitor is running -> click on the GPA Monitor icon in the task tray in Windows -> click on 'About...' -> Click on the 'Save to File...' button.
