Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Crash analyzing a frame
Oliver_S_
Hey there,
I'm getting a crash trying to analyze a frame in the Frame Analyzer (I've attached the frame to this thread, along with my PC info). The only message I'm getting is :
An unexpected error occurred.
Any ideas what's going wrong here?
Thanks for the help!
Neal_Pierman
Valued Contributor I
I'm getting a similar error loading this file as well. Let's see what the development team finds with this file.
However, I suspect the file contains bad data, which means we'll need a copy of the app which you used to create this file.
Neal
ps-> by the way, do you get any errors from DX when running this app (that is, does this app run "clean" when using debug mode with DX?).
Oliver_S_
Hi Neal,
Yeah the app runs clean in debug mode, I bail out on any DirectX errors.
I've attached a copy of the application, you won't see much when you run it... trying to set up deferred rendering at the moment and have a problem with the quad renderer I'm using when rendering a directional light.
Thanks!
Oliver_S_
I figured out part of the problem with the shader I've been using; the pixel shader didn't like me using POSITION as an input semantic for the vertex position - modifed it to SV_POSITION.
I'm not sure if that's the issue I've been having with GPA, I'll test it out when I get home tonight.
Oliver_S_
Looks like that was the issue, I can capture and analyze frames without any problems after the modifications to my vertex/pixel shader.
Neal_Pierman
Glad this now works... I'm assuming that I should close this issue?
Thanks again for using Intel GPA.
Neal
ps-> I've downloaded your app and removed it from the site.
Oliver_S_
Hi Neal,
Yeah close away!
