Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
554 Discussions
Endless frame loading in Graphics Frame Analyzer
VictorDR
I want to test the game Indiana Jones and the Great Circle. The frame dump works without any problem but when I try to load such a frame in GFA then it takes forever (I even waited few hours) and nothing happens, just a spinning circle all the time.
What could be the cause of this?
I found such line in GFA log file:
.\Sources\Utils\Utils\DataSocket.cpp(128): CAcceptorSocket::Listen GPA WARNING 0x3738 21.889988 Unable to bind listener socket to port # 1113. Error 10048 at bind().
and in GPAPlayer log file:
C:\jenkins\workspace\gpa\Sources\CapturePlayback\Stream\player\StreamPlayerConnection.cpp(126): StreamPlayerConnection::Open StreamPlayer ERROR 0x191C 0.717308 Could not perform MD source usage setup: Unable to load Intel GPU metrics library. (8)
sentientSpark_Intel
Hi VictorDR,
Thanks for your message.
Unfortunately, Intel Graphics Performance Analyzers doesn't support this title currently. If you encounter a situation where the loading spinner continues to spin indefinitely, this may be a sign (in addition to playback errors) that the title is not currently supported. We are sorry for the inconvenience this may cause. Feel free to check back next year using future releases of Intel GPA as we may support it in the future.
