Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
530 Discussions
GPA 3.0: how to capture a frame when running full-screen mode
intelsallu
how do u capture frame when application is running in full screen mode?
when its minimized u have to restore it!! is there a shortkey or something for capturing frame?
Neal_Pierman
Valued Contributor I
The GPA Monitor provides a means of capturing a frame via a key sequence -- by default the "CTL-SHIFT-C" will capture a frame.
To change the default, right-click on the GPA Monitor in the notification tray, select "Preferences...", and then select a key sequence that works best for you.
Thanks for using GPA, and let us know if you have any further questions on using the toolset.
Neal
Neal_Pierman
Neal
