Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
GPA create invalid environment variable
BradChang
After installing the GPA, it create two environment variable  in Windows 10.
GPA_GLOBAL_INJECTION_MODE
GPA_GLOBAL_INJECTION_TYPE
both of these values are '0x01'  (can't be seen with notepad)
These values cause some issues with my Visual Studio 2019 and can't be resolved.
I try to uninstall GPA, but these two environment variables are still there.
I also try to manually delete these values, or set these values to a valid character, but after I reboot my system, these values are back...
Is there anyway to solve thise?  Thanks.
Pamela_H_Intel
Brad,
I will check with the development team on how to remove those.
How did you learn that it is these 2 env vars that are causing issues with VS?
Pamela
Pamela_H_Intel
Brad - can you tell me how you discovered that it is those particular env vars that are causing your VS issues?
Pamela
Pamela_H_Intel
Brad - how did you discover that those particular env vars interfere with VS?
Also, please tell me what your platform is (processor/gpu) and which version of GPA you installed.
Pamela
