Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
GPA crush when use
邓__道宽
Hi
    Recently I tried using the GPA tool in the project, but the runtime is directly coredump.
    # LD_PRELOAD=./libGPA.so  ./gears
    GPA interceptor init
    GPA attaching context
    GPA loading settings
    init in constructor
    Memory fault (core dumped)
    My Project struct is like below:
    main --(dlopen)---> libRenderEngine.so ----(link)----> libEGL.so/libGLESv2.so
    But if I extra link the main program with libEGL.so and libGLESv2.so,it works.
   Is the GPA library call dlsym(RTLD_NEXT, "XXX") to store the real XXX at initialize and once ?  So if the main program is not link with two librarys, then the GPA can not get the right real function and lead to core dump if call.
 How can I fix this problem without modify my code and library dependencies?  please give me some advices,thanks!!
Giselle_G_Intel
Thank you for reaching out to us with your issue. Let's see what we can do to get you up and running with Intel® GPA. It looks like you're trying to run an OpenGL ES application, is that right?
Are you connecting System Analyzer to an Android device? Can you send me your system specs. for the system you're trying to profile? Or are you trying to use Intel GPA SDK to automate frame captures?
邓__道宽
>>Yes. The system specs is QNX7.0 + OpenGL ES2.   I just modify a gleas2-gears application with the struct I said before for test:
>>I'm not good at android development. So I have not tried this way yet.
If you need, I will send you the executable program through email.
Giselle_G_Intel
Unfortunately, Intel® GPA does not currently support QNX operating systems. The only supported systems for profiling are macOS(10.12, 10.13, and 10.14), Windows(7, 8.1, and 10), and Ubuntu (16.04 & 18.04).
Keep an eye on our releases to see if we release support for additional operating systems.
邓__道宽
We just make it work with a temporary solution.Although this looks less friendly.
This problem maybe not related to the operating system. Just about how to resolve the symbols.
Thank you for your reply. I will continue to pay attention about it.
