Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
533 Discussions
GPA frame analyzer can't open a frame and popup a message "An internal error has occurred ..."
RussellLuo
Recently I find that GPA can't open frame I captured and popup a ERROR message as follows.
I reinstall my os, it works. However, it failed again after a few days. It's annoyed me very much.
I have checked the log file in "C:\Users\***\Documents\GPA\Logs\FrameAnalyzer". The GPA try to bind listener socket to port from 1112 to 1211 and all failed with error code 10013.
How can I fix the problem!
The necessary information of my environment as follows:
Operating System:
Name: Windows 10 Version 2009 (OS Build 22621.1105)
Locale: zh-CN
Secure Boot/Trusted Boot is disabled
CPU Information:
Name: 12th Gen Intel(R) Core(TM) i7-12700KF
Architecture: x64
Cores count: 20
System BIOS:
Version: American Megatrends Inc. 0605
Date: 11/12/2021
GPU Information:
Name: NVIDIA GeForce RTX 3050
Vendor id: 0x10DE
Product id: 0x2507
Stepping: 161
Driver Version: 31.0.15.1740
Driver Date: 9-12-2022
Machine:
Memory: 32577 MB
Screen: 2560x1440, 32 bit
Graphics Performance Analyzers:
Version: 22.4.1671013788
Commit hash: bb72c912
Installation folder: C:\Program Files\IntelSWTools\GPA\
The attachment is log file.
RussellLuo
I have fixed problem by myself.
The reason is the ports (from1112 to 1211) used by gpa are reserved when I enable Hyper-V. You can fix the problem as follow steps.
1. Open cmd.exe as administrator.
2. Disable Hyper-V and reboot.
   dism.exe /Online /Disable-Feature:Microsoft-Hyper-V
3. Set dynamic port as a larger number than 1211.
    netsh int ipv4 set dynamicport tcp start=1250 num=16383
    If we set dynamic port number start from 1250, the windows will not reserve port small than it after enable Hyper-V.
4. Enable Hyper-V and reboot again.
   dism.exe /Online /Enable-Feature:Microsoft-Hyper-V /All
You can find more by about dynamic port in https://learn.microsoft.com/en-US/troubleshoot/windows-server/networking/default-dynamic-port-range-tcpip-chang
I hope it will be helpful for someone who encounter the same problem.
RussellLuo
Pamela_H_Intel
Wonderful Russell! Thank you so much for posting the workaround.
