Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
No metrics available on YOGA Tablet 2-830LC
Frank_C_
Hello, I was trying to profile our Unity game(Unity 5.6.2p1) on YOGA Tablet 2 with Intel GPA 2017 R2.
But GPA Frame Analyzer is not showing metrics and does not update render result when I changed a draw call.
Then I made a test scene with with a cube only, and GPA is still not responding.
I checked the FrameAnalyzer log, it shows:
location function component kind thread timestamp message
.\gasless\modules\DataModels\MetricViewerDataModel.cpp(602): MetricViewerDataModel::handleProcessorErrors "MetricsProcessor" ERROR 0x26A8 23.734472 Not enougth metrics to enable pipeline view
.\gasless\modules\DataModels\MetricViewerDataModel.cpp(69): ApiStream::Play APISTREAM ERROR 0x25FC 18446737429.694386 Failed to playback stream
.\GLESCapturePlayback\playback\GLPlaybackManager.cpp(459): GLPlayback::GetMetricValues GPA ERROR 0x25FC 18446737429.695072 ::internal::unconditional_alert() 'error::FailedTo.Get.Metrics.Value(e.what()):Failed to playback stream'
And the logcat shows something like:
08-02 15:46:58.683: D/MetricsFramework(11819): ExtensionLoader INFO[11819][3957742848]: Loaded 5 extension objects from /data/data/com.intel.gpa.packageinfo/files/x86/libigm_defaultmanager.so
08-02 15:46:58.683: D/MetricsFramework(11819): ExtensionLoader INFO[11819][3957742848]: Loaded 1 extension objects from /data/data/com.intel.gpa.packageinfo/files/x86/libigm_baytrailpublisher.so
08-02 15:46:58.683: D/MetricsFramework(11819): ExtensionLoader INFO[11819][3957742848]: Loaded 1 extension objects from /data/data/com.intel.gpa.packageinfo/files/x86/libigm_gfxdrvsampledpublisher.so
08-02 15:46:58.683: D/MetricsFramework(11819): ExtensionLoader WARNING[11819][3957742848]: Failed to load extension GfxInProcPublisher : This extension is not supported on this platform.
08-02 15:46:58.698: I/KERNEL(11819): [ 1978.816849] binder: 11819:11862 transaction failed 29201, size 68-0
08-02 15:46:58.683: E/COREU_CLIENT(11819): getPavpSessions - Transact return code -2147483646
08-02 15:46:58.683: E/(11819): [MDAPI] CreateContext: NULL coreU interface
08-02 15:46:58.683: E/COREU_CLIENT(11819): enableMetricsDevice - Transact return code -2147483646
08-02 15:46:58.683: E/COREU_INTERFACE(11819): CoreUEnableMetricsDevice - Error submitting transaction.
08-02 15:46:58.683: E/COREU_CLIENT(11819): getMetricsDeviceInfoParam - Transact return code -2147483646
08-02 15:46:58.683: E/COREU_INTERFACE(11819): CoreUGetMetricsDeviceInfoParam - Error submitting transaction.
08-02 15:46:58.699: I/KERNEL(11819): [ 1978.817772] binder: 11819:11862 transaction failed 29201, size 96-8
08-02 15:46:58.703: D/MetricsFramework(11819): ERROR[11819][3957742848]: GM_STATUS_DOES_NOT_EXIST: root = 15497066860149147674
I used the same Android device with GPA Frame Analyzer 2016 R3 and I was able to get metrics then.
I wonder whether I could have access to GPA 2016 R3 (I could not find old version download link on website) and make a quick test.
Thank you very much.
Frank
Giselle_G_Intel
Hey Frank,
I hope you received my message. I sent one and it seemed to not send so I sent another, fingers crossed that I did not spam you with too many messages.
Philip_C_
I'd be very keen to get a link to GPA 2016 R3 download as I have very similar issues!
Giselle_G_Intel
Hi Phillip,
The older build didn't resolve the issue, unfortunately. Frank ended up rooting the device to make it work with GPA.
