Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
Synchronization between a cpu core and gpu core
Doru_Adrian_Thom_P_
Hi! I was wondering if there is a way to sync two threads, one on the cpu and one on the gpu.
I am creating to cpu cores, one of the cores will offload to the GPU side and will have a lot of computation there. But at some point I need to sync them together. Is there a way to do that sync, through a barrier or something, cause I saw that volatile does not work.
EDUARDO_R___Intel_
Hi Adrian,
This question seems to be more related to development than it does performance tuning. I'll forward this to our developers and see if anyone has some insight to your particular problem :)
-Eddy
Doru_Adrian_Thom_P_
Ooops! I am really sorry. I saw graphics and I started writing. Thanks a lot.
Thom
Neal_Pierman
Valued Contributor I
Did you get your question answered? If not, I would also recommend that you post this question in the following forum: http://software.intel.com/en-us/forums/user-community-for-visual-computing
Neal
Anoop_M_Intel
Hi Adrian,
As of now Intel compiler provides support only synchronous calls to GPU. So any computation offloaded to GPU is a blocked call and the CPU thread will only resume after the computation on GPU side completes and returns.
Thanks and Regards
Anoop
