Intel® Graphics Performance Analyzers (Intel® GPA)
Improve your game's performance by quickly specifying problem areas
530 Discussions
The GPA System Analyzer crash on Android Nexus 5s
wang_v_
crash one device
info is:
--------- beginning of crash
01-07 13:17:41.324 14686 14686 E AndroidRuntime: FATAL EXCEPTION: main
01-07 13:17:41.324 14686 14686 E AndroidRuntime: Process: com.intel.gpa.packageinfo, PID: 14686
01-07 13:17:41.324 14686 14686 E AndroidRuntime: java.lang.RuntimeException: Unable to start activity ComponentInfo{com.intel.gpa.packageinfo/com.intel.gpa.packageinfo.PackageInfo}: java.lang.RuntimeException: Resource injector_arm64 not found in APK.
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2646)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:2707)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at android.app.ActivityThread.-wrap12(ActivityThread.java)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1460)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at android.os.Handler.dispatchMessage(Handler.java:102)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at android.os.Looper.loop(Looper.java:154)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at android.app.ActivityThread.main(ActivityThread.java:6077)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at java.lang.reflect.Method.invoke(Native Method)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:865)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:755)
01-07 13:17:41.324 14686 14686 E AndroidRuntime: Caused by: java.lang.RuntimeException: Resource injector_arm64 not found in APK.
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at com.intel.gpa.packageinfo.PackageInfo.installOrDelete(PackageInfo.java:791)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at com.intel.gpa.packageinfo.PackageInfo.onCreate(PackageInfo.java:239)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at android.app.Activity.performCreate(Activity.java:6664)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1118)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:2599)
01-07 13:17:41.324 14686 14686 E AndroidRuntime:     ... 9 more
01-07 13:17:41.328   889   960 W ActivityManager: Activity pause timeout for ActivityRecord{f9f433b u0 com.intel.gpa.packageinfo/.PackageInfo t13}
Ryan_G_Intel
Hi Wang Vasile,
I am sorry you are running into this crash.
I can pass this crash info along to our engineering team.  However, to replicate your issue on our side I will need to get some more information:
1) Can you provide the GPA 'About' dialog from the machine you are running GPA on?
2) At what point do you see this crash?  As soon as SA connects to the device?  Does this happen only after being connecting for a few minutes?
3) Are you able to connect to the device with anything other than SA?  FrameAnalyzer for example.
fang_f_
I have the same problem, but i'm use Xiaomi5, my windows system is win10,
about dialog is:
Machine name: DESKTOP-0382DN0
Windows 10 build 14393, 64-bit DEP enabled
Num Processors: 8
Memory: 63332MB
System BIOS: American Megatrends Inc. F6 (03/01/2016)
Video BIOS: Version 86.04.17.00.01  (05/09/16)
Driver 0:
     Device: NVIDIA GeForce GTX 1080
     Provider: NVIDIA
     Date: 12-29-2016
     Version: 21.21.13.7653
     VendorId: 10de
     ProductId: 1b80
     Stepping: a1
     No support for GPA Instrumentation
Driver 1:
     Provider: NVIDIA
     Date: 12-29-2016
     VendorId: 10de
     ProductId: 1b80
     Stepping: a1
Install directory: D:\Program Files\IntelSWTools\GPA\
Version: 17.1.308306
Current user is in Administrators group: YES
Current Graphics Performance Analyzers 2017 R1 (17.1.308306)
Secure Boot/Trusted Boot is Disabled
I have saw the esinfo app run twice and just terminate auto , and then i find the log with the error message the same as above. Both FrameAnalyzer and SystemAnalyzer will crash.
The application show this message "device error: Cannot get the applications list. Timeout occurred. Contact the Graphics Performance Analyzers support team."
Ryan_G_Intel
Hi fang fang,
You say you are using a Xiaomi5 device.  That device has a Snapdragon chip.  Unfortunately, we do not support Android devices that do not have an Intel chip.
FrameAnalyzer or SystemAnalyzer shouldn't be crashing on you though.  Would you mind walking me through the steps you are taking that lead up to the crash?  It would be helpful so I can recreate it on my side and get a fix for the crash.
Also, thank you for providing the GPA details!
fang_f_
I'm sorry, i mean the app start in android crash, not the app on pc crash. the app with title "gles info" run in android, and just crush after few seconds, then after a long time wait in pc app, it show  "device error: Cannot get the applications list. Timeout occurred. Contact the Graphics Performance Analyzers support team." message.
Ryan_G_Intel
Hi fang fang,
Ah, ok, I see - that's good the app on the pc is not crashing on you.  Unfortunately, as mentioned above, we do not support the device you are using since it is a non-Intel chip inside.  This would explain why System Analyzer/Frame Analyzer are having trouble talking to it.
If you have access to an Android device with an Intel chip we can try and get that up and running for you.
