Intel® High Level Design
723 Discusiones
An error(afu_fit.green_region.pmsf not exit ) occurred when I use aoc to compile OpenCL kernels on pac_a10 fpga board.
CLian11
Principiante
1.508 Vistas
An error occurred when I use aoc to compile OpenCL kernels(even official samples,such as hello_world.cl and vector_add.cl) on pac_a10 fpga board.
$ aoc -v device/hello_world.cl -o bin/hello_world.aocx -board=pac_a10
aoc: Environment checks are completed successfully.
aoc: Cached files in /var/tmp/aocl/ may be used to reduce compilation time
You are now compiling the full flow!!
aoc: Selected target board pac_a10
aoc: Running OpenCL parser....
aoc: OpenCL parser completed successfully.
aoc: Optimizing and doing static analysis of code...
aoc: Linking with IP library ...
Checking if memory usage is larger than 100%
aoc: First stage compilation completed successfully.
Compiling for FPGA. This process may take a long time, please be patient.
Error (213009): File name "output_files/afu_fit.green_region.pmsf" does not exist or can't be read
Error: Quartus Prime Convert_programming_file was unsuccessful. 1 error, 0 warnings
Error (23031): Evaluation of Tcl script a10_partial_reconfig/flow.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 7 errors, 3326 warnings
Error: Compiler Error, not able to generate hardware
When I compile any other kernels ,I also get this error.
I used to compile opencl kernels successfully, but now something went wrong.
How can I fix it?
my version of Intel fpga sdk for OpenCL is 17.1.1,my board is pac_a10.
Looking forward to your reply!Thank you very much!
0 kudos
1 Solución
3 Respuestas
MEIYAN_L_Intel
Empleados
1.357 Vistas
CLian11
Principiante
1.356 Vistas
Thank you for your reply!I have already solved this problem!​
MEIYAN_L_Intel
Empleados
1.356 Vistas
I am glad that your problem had been solved.
Responder
