Intel® High Level Design
722 Discussions
Aria is installed but it just doesn't work
HarukiOwO
Command:
yum install aria2 -y
PID:
30
stderr:
No Error
Output:
Last metadata expiration check: 3:33:50 ago on Sun Feb 26 04:45:43 2023.
Package aria2-1.36.0-3.fc37.x86_64 is already installed.
Dependencies resolved.
Nothing to do.
Complete!`
An error occurred probably an issue with aria2.
RichardTanSY_Altera
Which Quartus version and which Operating System that you are using to install?
Do you able to create a new project with Arria II devices?
Have you try to uninstall and reinstall the Quartus? You may try to install with the complete tar file.
p.s. Recommend to install the latest supported Quartus version.
https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/devices-support.html#intel%C2%AEarria%C2%AEseries
Richard Tan
HarukiOwO
Aria and Mongo DB doesn't connect while "testing" our project on  developer cloud
RichardTanSY_Altera
Are you referring to the Intel FPGA Dev Cloud? I am not familiar with this as I do not have the access to it and this seem to be under FPGA university program.
Could you go to "Request Intel® Developer Cloud Beta User Support​" > Request Support @ https://www.intel.com/content/www/us/en/developer/tools/devcloud/services.html
to file an IT ticket on the issue that you are facing?
I also saw a similar post in reddit with similar issue at reddit. Is this the same issue that you are facing?
https://www.reddit.com/r/FPGA/comments/lkyy8x/intel_devcloud_stuck_trying_to_access_quartus_on/
RichardTanSY_Altera
Add-on, double check if the license is valid as well. Though I am not sure if the environment is the same with Intel Dev Cloud.
Richard Tan
HarukiOwO
ok
RichardTanSY_Altera
Since there is not much that I can do in regards to this case, I now transition this thread to community support.
Thank you.
Richard Tan
