Intel® High Level Design
712 Discussions
Could you check if EP4CE6F17C8N
Lida8
Problem description:
PROBLEM FAILURE PHENOMENON: ICT test BGA open circuit, FT test can not write
Number of failures: 32 pcs
Defective rate: 32/1200 = 2.67%
Without any problem from exterior,X-ray and decap, but this IC chip can not programme.
Is it a new and original part?
(Virus scan in progress ...)
YuanLi_S_Intel
Parts which is purchased from our distributor is genuine. Please check if you are purchasing from our distrubutor.
https://marketplace.intel.com/s/pmp-partner-program/a723b0000008PICAA2/distributor
Meanwhile for the faulty device, have you tried to do swapping with known good device? Also you mentioned that FCT write and test is failing, any idea which pin is failing? Also, do you have the signal waveform that showing differences between failure and success?
