Intel® High Level Design
722 Discussions
Create call signals in Platform Designer to run IP block
FLoac
I could compile and synthesize the counter example correctly with the HLS compiler. I also added my newly created IP to my existing design in Platform Designer. But how can I generate the call and return signals now to run the IP block continuously?
MEIYAN_L_Intel
May I know what is the meaning of "call and and return signal" here?
Based on my understanding, "call and return signal" is transfer data or read data to the new IP block, am I right? If yes, you may need to connect avalon mm /avalon st/ conduit, the connection inside the Platform Designer is depend on your application.
For more information about avalon interface, you may need to refer the document as link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_avalon_spec.pdf
FLoac
Thank you for this helpful information.
I'm not sure if "call and return signal" is transfer data or read data of the IP block. I can't find any documentation on these signals and how they are generated by a function call by value in HLS. Are these signals generated just for the testbench or are they needed for communication between IP blocks. The following picture is the generated counter example in Platform Designer.
Is there an existing example how to generate an IP block in HLS, implement it in Platform Designer and run it on a FPGA.
Thanks!
MEIYAN_L_Intel
"Are these signals generated just for the testbench or are they needed for communication between IP blocks ", the signals generated to use for connection between IP block. After you have done the system connecttion in platform designer, you can be generated verilog code and run in Quartus. The generated HDL for component can also run in an RTL simulator.
For easily connects components in an Intel FPGA tom simplify system design , the HLS compiler will generate standard interface design for interoperability like avalon-mm, avalon-st and other interface.
All scalar arguments results in an input conduit while all pointer/reference arguments becomes address input.
"Is there an existing example how to generate an IP block in HLS, implement it in Platform Designer and run it on a FPGA", this can be done after use the HLS compiler compile the c code and then implement in platform designer as in chapter 8.2 with link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/hls/ug-hls.pdf
