Intel® High Level Design
722 Discussions
DevCloud - OpenVINO 2021
Tomasz_N_Intel
I want to run OpenVINO network on FPGAs: Arria 10 and Stratix 10 in DevCloud.
I've got 2 issues:
1. I see the latest OpenVINO release 2021.1.110 is installed in DevCloud. It seems that OV version does not support inference on FPGA any longer. How can I make it running? Can I switch somehow to use older version of OV that supports FPGA plugin?
2. I can only access nodes with Arria 10 with OpenVINO, but not Stratix 10.
When using 'devcloud_login', there is no OpenVINO Startix 10 option:
1) Arria 10 PAC Compilation and Programming - RTL AFU, OpenCL
2) Arria 10 - OneAPI, OpenVINO
3) Stratix 10 PAC Compilation and Programming - RTL AFU, OpenCL
4) Compilation (Command Line) Only
5) Enter Specific Node Number
Or when listing DevCloud nodes with 'fpga' property I see only two types:
pbsnodes | grep fpga
     properties = xeon,skl,gold6128,ram192gb,net1gbe,jupyter,batch,fpga_compile
     properties = xeon,skl,gold6128,ram192gb,net1gbe,fpga,arria10,fpga_runtime
How can I access node with Stratix 10 and run OpenVINO inference?
Tomasz
AnilErinch_A_Intel
Hi ,
The Devcloud gets updated with the latest software and stacks time to time.
It is not possible for a user to to role back to an older version until that is provided as an option by Devcloud scripts. .
The OpenVINO design examples which is currently available uses Arria10.
Thanks and Regards
Anil
