Intel® High Level Design
723 Discussions
FPGA report fails for matrix transpose
xwuupb
Hi everyone,
the FPGA report fails for a simple kernel for the matrix transpose operation. The output asks me to
PLEASE submit a bug report to https://software.intel.com/en-us/support/priority-support and include the crash backtrace.
But the web page does not work well for me. Thus, I attach the error messages and source code here.
  • The source code: attached.
  • The optimization report:
icpx -fsycl -fintelfpga -DFPGA_HARDWARE -std=c++2b -Wall -Wextra -Wpedantic -Werror -O3 mattrans.cpp -Xshardware -fsycl-link=early -Xsv -Xsparallel=16 -Xsffp-reassociate -Xsffp-contract=fast -o mattrans.a
  • The error messages:
Dependency files for SYCL source and SYCL-source library: /dev/shm/icpx-32a212/mattrans-1ee627.d
aoc: Environment checks completed successfully.
aoc: Selected target board package /opt/software/FPGA/IntelFPGA/opencl_sdk/20.4.0/hld/board/bittware_pcie/s10_hpc_default
aoc: Selected target board p520_hpc_sg280l
aoc: Processing SPIR-V....
aoc: SPIR-V processing completed
aoc: Linking Object files....
Device information not found: 1SG280LU3F50E1VGS1
aoc: Optimizing and doing static analysis of code...
Stack dump:
0.      Program arguments: /opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt -march=fpga -O3 -ipatemplate /opt/software/FPGA/IntelFPGA/opencl_sdk/20.4.0/hld/board/bittware_pcie/s10_hpc_default/hardware/p520_hpc_sg280l/board_spec.xml -board /opt/software/FPGA/IntelFPGA/opencl_sdk/20.4.0/hld/board/bittware_pcie/s10_hpc_default/hardware/p520_hpc_sg280l/board_spec.xml -vpfp-relaxed -sycl -dbg-info-enabled --soft-elementary-math=false -pass-remarks-output=pass-remarks.yaml mattrans.1.bc -o mattrans.kwgid.bc
1.      Running pass 'Function Pass Manager' on module 'mattrans.1.bc'.
2.      Running pass 'Mark the decision for loop pipelining' on function '@ZTS15mattrans_kernel'
Stack dump without symbol names (ensure you have llvm-symbolizer in your PATH or set the environment var `LLVM_SYMBOLIZER_PATH` to point to it):
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(+0x29c600f)[0x55f1186f700f]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(+0x29c2f1d)[0x55f1186f3f1d]
/lib64/libpthread.so.0(+0x12ce0)[0x1517e8435ce0]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN3acl6MemDep25BasicMemoryDependenceInfo24distinctTermsInLoopNestsEPN4llvm4LoopERNS_16VariableGEPIndexES4_S6_+0x436)[0x55f1193b00f6]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN3acl6MemDep25BasicMemoryDependenceInfo38distinctTermsInDifferentLoopIterationsEPN4llvm11InstructionElRKSt6vectorINS_16VariableGEPIndexESaIS6_EEmS4_lSA_mPNS2_4LoopE+0x1952)[0x55f1193b25f2]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN3acl6MemDep25BasicMemoryDependenceInfo38distinctTermsInDifferentLoopIterationsEPN4llvm11InstructionERKNS_24AddressDecompositionInfoES4_S7_+0xb6)[0x55f1193b3486]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN3acl6MemDep25BasicMemoryDependenceInfo21analyzeDecompositionsEPN4llvm11InstructionES4_bb+0xe4c)[0x55f1193b6a8c]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN3acl6MemDep31LoopCarriedMemoryDependenceInfo13getDependenceEPN4llvm11InstructionES4_b+0xc0c)[0x55f1193bc03c]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN3acl6MemDep31LoopCarriedMemoryDependenceInfo13getDependentsEPN4llvm11InstructionERNS2_11SmallPtrSetIS4_Lj2EEEb+0x2de)[0x55f1193be96e]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN3acl33LoopCarriedDepsBeforePipelineInfo12process_loopEPKN4llvm4LoopE+0x54d)[0x55f119527e0d]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN3acl16LoopPipelineInfo19check_serial_regionEPKN4llvm4LoopE+0x64)[0x55f11951da74]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN3acl16LoopPipelineInfo19runPipelineAnalysisEPNS_13ArrayPrivInfoEPNS_33LoopCarriedDepsBeforePipelineInfoEPNS_14LocalMemConfigEPNS_20RestrictInterleavingE+0xc3)[0x55f119521953]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN20MarkPipelineDecision3runEv+0x4c)[0x55f119a7100c]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN30MarkPipelineDecisionLegacyPass13runOnFunctionERN4llvm8FunctionE+0x3cd)[0x55f119a718cd]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN4llvm13FPPassManager13runOnFunctionERNS_8FunctionE+0x3eb)[0x55f117ca1f8b]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN4llvm13FPPassManager11runOnModuleERNS_6ModuleE+0x39)[0x55f117ca2199]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_ZN4llvm6legacy15PassManagerImpl3runERNS_6ModuleE+0x2fb)[0x55f117ca2aeb]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(main+0x20d4)[0x55f116bb3d44]
/lib64/libc.so.6(__libc_start_main+0xf3)[0x1517e4337cf3]
/opt/software/FPGA/IntelFPGA/oneapi/23.1.0/compiler/2023.1.0/linux/lib/oclfpga/llvm/aocl-bin/aocl-opt(_start+0x29)[0x55f116cde119]
Error: Optimizer FAILED.
Refer to /dev/shm/mattrans-96129e-fe9b4d/mattrans.log for details.
Many thanks
Xin
hareesh
i will check and update to you
hareesh
sorry for delaying. because of the workload, I was not able to respond to your issue.
if you don't mind may I know which document are you following? please share the document link.
xwuupb
I did not mention any documents in my questions.
hareesh
with shared information, i am not able to identify the issue. so, I am asking which document are you following.
i need some more information like what are trying to do and tool details, following steps.
please share the requested information.
xwu
The issue is clearly shown in "the error messages" in my question (see above).
I did not mention any document in my question.
My question indicates it clearly that the FPGA kernel does matrix transpose operation and the tool is icpx. The source code and steps to compile it are also clearly given in my question.
Please read my question carefully before asking questions!
hareesh
I didn't receive any response from you. could please share the requested information it may help us to identify the issue.
hareesh
I am trying to duplicate your issue so I need some more time.
xwu
1. download the DPC++ source code attached in the question.
2. execute the "icpx ..." line in the question.
To re-produce the issue takes 1 min in my opinion.
hareesh
same issue I also facing in my local machine. I need to discourse with the team.
and one more question shared code, is your own code or already available code in intel?
xwu
Its my own code.
hareesh
OK. just discussing with team and need some more time
hareesh
I am waiting for a response from the team.
xwu
Hi, your link is irrelevant to my question.
  • my question is about matrix transpose, but your link is about matrix multiply
  • my question is about FPGA programming, but your link is about CPU and GPU
BoonBengT_Altera
Hi @xwuupb,
Apologies for the confusion, with the provided source code we have managed to successfully run the emulator compilation. With that we can rule out the issues on the code.
Hence based on the error message provided above it seems to be mentioning about hardware device info not found.
Suspecting that the targeted hardware are not mention appropriately in the compilation command.
For full system compilation which I assume is the case here the BSP are required, for the supported BSP devices you may refer to the link below:
- https://www.intel.com/content/www/us/en/developer/tools/oneapi/fpga.html (For non PAC product, please scroll to the 'Choose an FPGA Platform' section)
- https://www.intel.com/content/www/us/en/docs/oneapi/programming-guide/2023-1/fpga-bsps-and-boards.html (For PAC product)
Hope that clarify, please do let us know if situation are still misunderstood.
BB
xwu
thank you for your answer! I think it may be a problem with the BSP shipped with the Bittware 520N card with Intel Stratix 10 GX 2800 FPGA. In the static report stage, if I give the compiler option -Xstarget with
  • the BSP for the Bittware 520N card, it fails with the error messages shown in my question (see the first thread of this topic).
  • the BSP of intel_s10sx_pac:pac_s10_usm, it succeeds in the report stage.
Does that make sense?
hareesh
any update?
BoonBengT_Altera
Hi @xwuupb,
If I remember correctly the mention 'intel_s10sx_pac:pac_s10_usm' are BSP for Intel PAC D5005, and suspect there would be some interconnect differences. (Note: no hard trying to compile and program but likely it would fail or not behaviour correctly)
Noted on the hardware involved, unfortunately as it is coming from Bittware, we would need them to provide the correct workable BSP to continue. Hence would suggest to get in touch with their support channels and provide them with the references design you are using to understand further.
Hope that clarify.
Best Wishes
BB
xwu
Hi @BoonBengT_Altera ,
Best wishes!
Xin Wu
hareesh
do you have any queries?
